04-08-2012, 09:46 AM | #1 |
speed way mustangg 2 suspension
has anyone used a speedway mustang 2 suspension kit yet i was wondering if something is wrong with it because no ones using it. its about 3-400 cheaper than any one elses though
04-08-2012, 09:54 AM | #2 |
and a few others
Re: speed way mustangg 2 suspension
I don't know about their M2, but everything I've bought from Speedway has been good quality. They carry a lot of parts that nobody else has.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
04-08-2012, 10:58 AM | #3 |
In talking to other people there are a lot of people that, surprisingly have never heard of Speedway. I like their stuff and most of it is cheaper than the other guys.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
04-08-2012, 11:11 AM | #4 |
I think Blackdiesel used a speedway kit you might want to PM him and ask him. Here is the link to his build
http://67-72chevytrucks.com/vboard/s...peedway&page=5
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
04-08-2012, 11:29 AM | #5 |
If I'm reading it right that is for the kit, then you order the crossmember off a separate page to go with those pieces. I poked around the kit page and didn't figure it out yet but that is the way it reads.
From http://www.speedwaymotors.com/Mustan...DisplayId=2089 Crossmember NOT included - Add proper crossmember to complete kit. You must specify POWER or MANUAL in the comments secton when checking out. You must specify the desired spring rate in the comments section when checking out: 700 lbs, 600 lbs, 500 lbs, or 375 lbs. Last edited by mr48chev; 04-08-2012 at 11:45 AM. |
04-08-2012, 11:35 AM | #6 | |
There kit's are truck specific they even have a new kit that is a bolt on for AD trucks.
04-08-2012, 11:57 AM | #7 | |
I changed my post before I saw your answer so that's why it looks a bit odd for your quote if anyone wonders. |
04-12-2012, 11:09 PM | #8 |
i just was at speedway today and bought their bolt in crossmember and rear leaf spring kit for my sons truck havent taken it out of box yet to look at it.
04-13-2012, 11:47 AM | #9 |
LET ME KNOW WHAT YA FIND LOW88 thanks for all the replies
04-13-2012, 01:38 PM | #10 |
it all looks good doesnt look to hard to install. we bought the weld in type and bought boxing plates . not 100% on my welding so we got this one. will just sell the other weld in stuff now.
04-13-2012, 02:43 PM | #11 |
The bolt in ones go in pretty nice and work great for guys who don't have a welder or don't weld. The price runs the same as buying a weld in and paying to have it welded in in the long run.
In some states, provinces and countries where modifying suspension might be frowned upon especially if it is welded on the bolt on setups may get through inspections a lot easier than weld in units. |
04-15-2012, 02:31 PM | #12 |
We just installed a speedway M2 in my 59 and went together well, and so far no quality problems. Everything fit great. I did the coil-overs and may have to go to a little heavier coils--Not done tuning up suspension yet. I have a triangulated four link in rear with coil-overs also. The only thing to watch is, I went with 2 inch dropped spindles, and the front end is pretty low. Be careful to figure out how low you want your ride to be!! The bottom of my frame rail in the front to the ground is 7.5 inches right now 225-55-17 tires.
04-15-2012, 05:35 PM | #13 |
At 7.5" that is low. Could you give us a rear measurement? And what size rear tire are you running? Speedway has been in business for many years. They have to be doing something right, and quality would have to be there over that many years.
04-15-2012, 07:37 PM | #14 |
check out my build thread I used it and like it, I startered out with the 2" drop spindles and it was to low with out notching the frame in the rear to get it close to level. But you can see the whole prossess of putting it in on my thread.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
04-15-2012, 08:01 PM | #15 |
Look at post#4 on this thread I set up a link to your page.
04-15-2012, 11:21 PM | #16 |
thanks for the link i feel much more comfortable about purchasing their mustang 2 front end kit
04-16-2012, 11:24 AM | #17 |
The measurement on the rear end of my truck,(right now) is 17 inches from bottom of frame rail at the rear of the truck to the ground. That's without gas in the tank (rear frame mounted). The tires are 255/50/17 on the rear. I had the front tire size wrong, they are 225/50/17s (sorry bout that). I may have a problem in the rear with the top of the rearend about 2.5 inches from hitting the bed floor. So again be careful with your ride height. I am now having a few issues. Truck not on the rode yet!
04-16-2012, 11:25 AM | #18 |
What year of truck are you doing??
04-16-2012, 11:56 AM | #19 |
im building a 54 chevy
04-17-2012, 06:17 PM | #20 |
dont buy speedways bolt in front crossmember it wont go around the outside of the frame rails im taking the one i bought back. spent over an hour trying to get it to fit. to make it fit i would have to cut the outside tab off to make it fit . going to keep the weld in crossmember i have and put it in.
04-17-2012, 06:21 PM | #21 |
from what i can tell they have never tried to install one on a frame before.
04-17-2012, 07:07 PM | #22 |
Here at Scotts hotrods we have the cure our crossmembers are built to your truck frame specific.Yes I already know we are more $$$$ than Speedways and more than some others on the market.You have to ask yourself what is your time worth?We have some GREAT DEALS FOR ALL THE MEMBERS HERE on this site.Most of all we are on this forum daily to help out members here.If you are interested in seeing what we can do for you.Please feel free to call us and you will see how much $$$$ you will save.You can reach us at (805)485-0382 our toll free number for ORDERS only is (800)273-5195
04-17-2012, 07:12 PM | #23 |
i was buying a weld in anyway id rather locate the suspension in the truck my self thanks for all the replies
