04-09-2012, 11:38 PM | #1 |
I had a V-8
Remove Overspray From Brand New Tires??
I got some overspray on a brand new set of tires. Single stage urethane (mean stuff). It is very dry now as I did not realize I did it until now. I know some chemicals that will take it off, but I don't want to ruin or reduce the life of the tires by using it.
Anybody know a safe way to remove overspray from new tires??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
04-10-2012, 12:22 AM | #2 |
US Army Veteran
Re: Remove Overspray From Brand New Tires??
Not sure what to recommend to get it off, however, I have used a product called Forever Black on tires, black plastic trim, rubber seals, etc and it works very well. It "soaks" into rubber and covered up some overspray I had on some old rubber seals.
1972 C10 Highlander - The making of a daily driver |
04-10-2012, 12:42 AM | #3 |
you can try adhesive remover or maybe you a scotch brite pad or a sos pad, I use to put vasoline on the tire and then you can paint the rim and then just spray off the vasoline. but if you forget to cover the tire when you spray the body that sucks
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
04-10-2012, 02:04 AM | #4 | |
I had a V-8
It is not quite that much. I was painting a couple panels over here and the tires were over there. The paint rode a breeze over to the tires so it is not very heavy/thick. I forgot how evil the overspray from single stage urethane is or I would have tarped the stack of tires. Ugh.
04-10-2012, 06:56 AM | #5 |
Maybe a little enamel reducer?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
04-10-2012, 09:11 PM | #6 |
E.H.F.D Engine #2
black spray paint....
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
04-10-2012, 10:46 PM | #7 |
try paint striper or brake fluid
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
04-11-2012, 12:08 AM | #8 |
Have em flipped on the wheel!
04-11-2012, 07:23 AM | #9 |
i'd try hot water and soap with a brillo pad first
04-11-2012, 04:41 PM | #10 |
The Magic Eraser
Scott |
04-14-2012, 07:22 PM | #11 |
Back in the 60's we used brake fluid on suspension rubber parts for a lube, should work great on your tires to remove paint, it will remove the paint on the car, just don't get it on the tread !!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-15-2012, 02:15 AM | #12 |
I had a V-8
There are some good ideas in here, but I think I am going to try the brake fluid route first. I had a "weekend project" that is currently entering its third week so I haven't had a chance to get after this project. I was talking with a buddy of mine and he said back in the days prior to ArmorAll, his dad would shine up the tires on his vehicle with some brake fluid and we all know how destructive it is to automotive paint, so I figure it is a good place to start. Just curious, why do you say to keep it off the tread??
I will report back with my results in case someone else forgets to cover a brand new stack of tires when they blow several coats of single stage urethane nearby.
09-08-2012, 08:36 PM | #13 |
lacquer thinner and elbow grease .
09-08-2012, 10:45 PM | #14 |
just an fyi brake fuild on tires will dry the rubber out as will lacquer thinner
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-14-2012, 12:52 PM | #15 |
Bug and tar remover works well.
01-17-2013, 01:08 PM | #16 |
I'm just glad to be here!
I always used enamel reducer on a rag for getting it off the rubber. Afterward, I would clean it with soap and water and then apply a protectant to keep the rubber from drying out. Always worked welll for me.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-17-2013, 04:38 PM | #17 |
Glass bead blasting will work if you remove the tires.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-17-2013, 05:52 PM | #18 |
The Older Generation
No matter how you clean them you need to re-coat them with a protectant. Here is some info I found on the net...
To protect tires, manufactures add a wax compound to reduce ozone and water damage. The wax is designed to sit at the surface of the tire and form a protective barrier between ozone and water, and the tire rubber. The wax only moves to the surface, when the tires flex. This happens every time you drive, and is called “blooming”. Cars that sit for extended periods of time don’t experience blooming, and are unprotected against ozone. Combined with UV light, drying, discoloration and cracking begin very rapidly. The solution is tire dressings. Tire dressings are designed to protect the tire, restore essential moisture, and condition the rubber. This is why it is important to use a quality tire dressing. You want a dressing that not only provides UV protection, but also is devoid of chemicals such as petroleum distillates. Recommended Dressings: Lexol Viynlex, Aerospace 303, Pinnacle Rubber Protectant, Zaino Z-16, and Meguiars Endurance. LockDoc
01-17-2013, 08:40 PM | #19 |
Parts and more parts
Frank |
01-18-2013, 12:01 PM | #20 |
bug and tar remover works great
01-18-2013, 10:26 PM | #21 |
Tot Roddin'
Since this was initially posted back in April of '12 any updates?
What worked?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-20-2013, 02:26 PM | #22 | |
I had a V-8
01-20-2013, 02:30 PM | #23 |
I had a V-8
Well, one would think there should be an update, but to be honest, I haven't even had a chance to install the panels I painted that created this overspray, much less clean the overspray off the tires. Events seem to conspire against my available time . I do appreciate all of the great ideas presented here and I will definitely post up what I try and whether I can get it to work or not.
02-07-2013, 07:38 PM | #24 |
Sand blast em makes em look brand new
02-07-2013, 10:26 PM | #25 |
I used Comet cleanser to get urethane off my tire, it worked great. I always use comet to clean my tires anyway, they come out super black and if you have white lettering in them they will turn out very bright white.
http://smg.photobucket.com/albums/v655/aaronhero/ |
