Old 04-11-2012, 10:26 AM   #1
padresag
V6 a/t adaptor-ebay
http://www.ebay.com/itm/1965-1966-19...1df52f&vxp=mtr
ron
padresag is offline   Reply With Quote
Old 04-11-2012, 10:32 AM   #2
1963c-10
1963c-10's Avatar
Re: V6 a/t adaptor-ebay
Good find there
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-11-2012, 11:12 AM   #3
Andyboy
Andyboy's Avatar
Can you put a 350 tranny with that adapter? Or just the th400?
Andyboy is offline   Reply With Quote
Old 04-11-2012, 11:44 AM   #4
padresag
yes you can put a 350 behind it or a 700r4
ron
Old 04-11-2012, 12:58 PM   #5
61K10
61K10's Avatar
don't for get the 200R same length as a 350 and uses the same d/s yoke. the rear mount is just farther back. ran one in my 65 chevelle el/co with non lock up converter. good little overdrive.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-11-2012, 04:50 PM   #6
Andyboy
Andyboy's Avatar
I have a 62 gmc with a v6 305 backed with a auto hydramatic. The adapter I have is not the same one there selling Right?
Old 04-11-2012, 04:52 PM   #7
padresag
no. that is only for the hydramatic
ron
Old 04-11-2012, 05:44 PM   #8
Andyboy
Andyboy's Avatar
ron
Thanks Ron,
Sorry for all the questions but don't know to much about these 305's. What else would I need to make this work with a 350.? starter, driveline ?
Old 04-12-2012, 08:07 AM   #9
duallyjams
duallyjams's Avatar
It's missing the 2 support rods that go from the trans to the engine but if it sells for 200 that's a good deal as these go for 400.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-12-2012, 10:10 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
ron
what about the other way I found a gmc w/ a hydro, would a chevy motor bolt to it, or would I have to find an adapter for gmc hydro to chevy?
Old 04-12-2012, 10:15 AM   #11
Andyboy
Andyboy's Avatar
Are the 2 support rods easy to come by?
Old 04-12-2012, 10:24 AM   #12
padresag
you would have to find the adaptor to bolt it to a chev
ron
Old 04-12-2012, 10:27 AM   #13
padresag
what are these support rods? any pics of them?
what are these support rods supposed to accomplish
ron
Old 04-12-2012, 03:25 PM   #14
Andyboy
Andyboy's Avatar
ron
x2
Old 04-12-2012, 07:40 PM   #15
duallyjams
duallyjams's Avatar
Instead of a word search this is a V6 auto adapter search can you spot all the correct pieces
James
IG duallyjams
Old 04-12-2012, 08:02 PM   #16
Andyboy
Andyboy's Avatar
Yeah, the 4 pieces that their selling and the 2 support bars. How about that starter? Will the one I have work? I have the hydramatic.
Old 04-12-2012, 08:06 PM   #17
duallyjams
duallyjams's Avatar
This would be the best place for info http://www.6066gmcguy.org/ oh and the starter is in the pic also along with a 401M.
James
IG duallyjams
Old 04-12-2012, 08:16 PM   #18
padresag
Attachment 907266
what do those rods actually support. the eng is side mounted and the trans will be rear mounted. the eng and the trans are not going to fall apart. what function do they really do?. is their application in a light duty truck or in a medium duty?
ron
Old 04-12-2012, 08:28 PM   #19
duallyjams
duallyjams's Avatar
With the weight of the engine then add a adapter with a aluminum case auto that equals stress.
James
IG duallyjams
Old 04-12-2012, 08:51 PM   #20
padresag
I doubt it'
ron
Old 04-12-2012, 08:57 PM   #21
A.T. RockDriller
A.T. RockDriller's Avatar
I sure agree with you, James.
I've got pictures on here of mine in my thread "Rockdrillers "63" or something like that.
I show it both on the ground in pieces and being assembled...hanging from a hook.
It is easier to wrap yer head around when ya see it hanging in one piece, but I don't know how to find the thread.
If you consider the over-all weight of the BB V-6 and the distribution of that weight.....heavy to the rear...it's understandable why the struts are used.
The V-6 side mounts are positioned pretty far forward, so with the auto tranny mount being where it is....I'm sure it is not beyond engineering common sense to incorperate them into the design.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-12-2012, 09:06 PM   #22
A.T. RockDriller
I think I found my thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=453161
We'll see if this works....
Whammo....
If you look at post's #85 and #87 you see how far forward the mounts on the V-6 are.
I thought I had pic's of the whole Marry-Anne, but I guess not.
Anyway....you get the picture.
The front mount position coupled with where you already know the auto tranny mount is..
and....yes Virginia....there might be some stress..
But you probably could run it that way. The Powerglide has a much stronger case in that way, so might have never used one.
It just makes me think back to the type of mechanic that I can't stand.....the guy that throws the end brace from the Delco starter to the engine block away sayin' "you dont need those" (and then b1tchin 'bout a cracked end housing )....because he doesn't want to replace it. Or the spark plug shields off a factory stock engine...or any other component that belongs there and should go back when they are finished.
I can hear him now.....Awe....ya don't need those ....They don't do nuthin...And then throwin them in the scrap barrel.
I know...it's a pain. In fact, mine were really a pain in the a$$....but they're in there.
Les Hunter
Old 04-12-2012, 09:52 PM   #23
A.T. RockDriller
Guys...I might be misunderstanding the question....but I beg to differ.
If you have a Vee Six with a Turbo-Hydromatic tranny....then the tranny is a GM six bolt patterned design....and the adapter starts in front of that....and goes all the way to the GMC engine block....which will bolt directly to a GMC Truck Bell Housing.
Unless the sixty two's are different (and they might be)....the automatic adapter assembly allows you to bolt the GMC Vee Six to any standard GM automatic tranny... TH350, TH400, TH700r4, and all and any of that generation ....and if it works for one it'll work for the others.
There are two different adapter assy's....not sure what the year break is(it might be '62).
One has the round design flex plate (for lack of a better term)....and one has the triangular flex plate...like mine and the one on e-bay and the one D-jams posted.
Ya will see mine on post #85 on my build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=453161.
But....they both work the same and are interchangeable...one for the other.
So yes...Andyboy....yers is the same.
But....as far as the struts themselves....they are unique to the TH400.
The tranny end will be tranny specific in all cases.
Les Hunter
Old 04-12-2012, 09:53 PM   #24
padresag
thank you, i see how it all goes together now. those more than likely get thrown away 9 out of 10 times. I have see quite a few of those adaptors for sale but the rods never seem to be inc
ron
Old 04-12-2012, 09:55 PM   #25
Andyboy
Andyboy's Avatar
Do you think you can make those bars, If there not easy to find?
