Old 04-12-2012, 11:41 PM   #1
K5 Addiction
K5 Addiction's Avatar
Clifford heated Intake
Does anyone have pictures of how they ran the Heater hoses cleanly?
K5 Addiction is offline   Reply With Quote
Old 04-13-2012, 08:38 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Clifford heated Intake
This is the L6 in my friend Dave's Chevy II wagon...he uses an Offy intake, but the principle is still the same. He's using the port in the head closest to to the inlet for the manifold and then to the heater core, but I've seen some that used one of the ports on the water neck extension and then to a rear port in the head.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-13-2012, 09:25 AM   #3
1963c-10
1963c-10's Avatar
The splatter paint looks good in the engine compartment. Very clean
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
