Old 11-23-2000, 09:05 AM   #1
Mike Wessinger
Mike Wessinger's Avatar
Post Carb question
I have a 1965 C-10 with the 230 inline 6. The previous owner "fixed" a fuel leak at the carb by using JB Weld to seal the fuel filter coupling to the carb body, permanently. The carb is in need of replacement.
I have a 235 carb readily available. The online parts vendors I have visited looking for answers all list the same carb for the 230 and 235. Will this carb work on the 230? Is it the same body with a different jet that I could take from the old carb?
Thanks for any help.
Mike
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 11-23-2000, 11:47 AM   #2
ImpalaSS
Post
230? theres such a thing? sure it isnt a 235?
(correct me if im wrong)
i bet the carb works just fine,,,, try it out those straight 6's are EASY to work on
xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside
64ImpalaSS 68 large journel 327 turbo 350
ImpalaSS is offline   Reply With Quote
Old 11-23-2000, 12:22 PM   #3
Mike Wessinger
Post
Thanks ImpalaSS.
I am pretty sure it is a 230. At least, the owner's manual gives an engine color code, for which blue is a 230 L-6, and I can still see blue under all the oil and grime.
The only other engines listed in the owner's manual, besides the 230, are a 153 L-4, a 292 L-6 (I know it't not this one), and a 283 V-8.
I guess I will go ahead and give it a try this weekend.
Thanks,
Mike
