Old 04-13-2012, 09:51 PM   #1
krisackermann
new member 66c10
hey guys new here. own a 66 c10 stepside longbed project. i am hoping to convert it 4x4 and had a question. i was looking like 1978 to 1982 chevy 3/4 ton 4x4 for a doner. do u think it would be a huge project to fit the suspension axles transfer case ext. on my 66. or would i be easier to just fit the body of my rig to the newer chassis. thanks
krisackermann is offline   Reply With Quote
Old 04-13-2012, 10:58 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: new member 66c10
Welcome aboard, I don't want to suggest any answers to your question since it's a 4x4, but someone will.
Alan's Classic is offline   Reply With Quote
Old 04-13-2012, 11:03 PM   #3
rcbildr
rcbildr's Avatar
From what I've read and been advised from other members here, it's better to stick with your original frame. You would need a donor truck for the spring hangars and drivetrain parts tho. I'm finishing a 4x4 conversion on my 63. I bought the truck from a friend of mine (known him since high school) and actually helped him start the project several years ago. He already had the springs positioned close to where they need to be and bought a front axle for it. I've since got rid of the axles that were on the truck and have a pair from an 83 chev 4x4. I've got a build thread in the 4x4 projects forum.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 04-14-2012, 12:46 AM   #4
Captainfab
60-66 Nut
Which way to go partly depends on your fabrication skills. It is my opinion to keep your original frame and add the necessary spring hangers, crossmembers, etc. for your 4x4 conversion. While I have not done a 4x4 conversion, I have installed a '60-'66 body onto a '73-'87 frame. I would not do it again.
