Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 04-14-2012, 11:44 AM   #1
6772owner
Gearhead
6772owner's Avatar
Question on value
Ok guys im in need of an opinion, what do guys think a realistic value of my truck is?
The truck is a 72' C10 original short bed frame (now fleetside), 96' fuel injected LT1 Camaro engine (apx 95,000 miles), 90' 700R4 trans (apx 20,000 miles), full air ride (ECE rear kit, D2600 front bags on DJM arms, Viair 380C, paddle valves and gauges, front sway bar), 255/55/18 tires, new windshield and one piece rear window, new carpet, dash pad and lower door panels, column shift/tilt wheel, non-a/c cab, Blazer bucket seats w/decent covers, CD player w/4 speakers, 2-way alarm/remote start, new GM battery, trans cooler, Camaro aluminum radiator/electric fans, Pacesetter ceramic headers and 3" single exhaust, rear mounted fuel cell w/external Walboro 255 fuel pump, Pace Edwards Full Metal Jack Rabbit tonneau cover, new rear bumper and brackets, ECE hidden receiver hitch.
Here are a few pics...
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-14-2012, 12:12 PM   #2
dan42
dan42's Avatar
Re: Question on value
IMO, you have a nice truck with lots of extras. If you are looking to sell, I would clean up some of the small stuff - stereo in the dash, wheel center caps, etc. Without knowing what the rust issues are it's hard to say. Shortbeds are obviously worth a little more, and depending on how clean the drivetrain has been installed, it could be a desirable truck for someone.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-14-2012, 03:25 PM   #3
6772owner
Gearhead
6772owner's Avatar
Those were some under construction pics from when I painted everything, the truck is all back together now. As far as rust, it needs cab corners (I have the patches), inner/outer rockers and the rear cab supports. I have new floor pans for it as well, but they are patched up right now. The engine is installed with factory replacement urethane mounts (67-72'), wired with a modified GM harness, I think its pretty clean. The trans was installed with an ECE crossmember, vacuum lock up kit, custom one piece driveshaft. The governor has been tuned to the truck and the speedo gears swapped as well. With the tire size and 3.73's, it runs pretty well and cruises nice at speed.
Im thinking in the $8-9k range?
Old 04-14-2012, 04:13 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
It looks like you have done alot of work, but will still need plenty to finish. If i was looking at it in this part of the country, maybe around 4k.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
