Old 01-15-2001, 10:03 PM   #1
Toddro
Post 62 rearend
I am pro streeting my 62, which has the stock 10-bolt, 6 lug rear in it. I have no idea of the ratio (any idea how I'd find out?) and I was wondering if it's worth keeping or not. It is the right width for the wheels I have, but I would need to find a way to change it to a 5-bolt pattern to match the front 72 suspension. Has any body had any experience with these rearends, are they strong enough for daily driving and limited strip use? How hard will it be to rebuild? Is this thing worth my time, or should I start looking for an 8 or 9 inch to slide under it?
'70 Chevy C10 longbed: bone-stock!
'72 Lincoln Mark IV: yeah, I know it's a Ford, but it's cool! Soon to be smoothed and bagged...
Toddro is offline   Reply With Quote
Old 01-15-2001, 10:23 PM   #2
ImpalaSS
Post
to get it to 5 lug a 71-72 chevy/gmc rear end will bolt in,,,
and to check for gears pull the rear cover and on the ring gear it should have some #s.. divide those togther and WALA! you have your gear ratio,,,
<A HREF="http://www.geocities.com/xframeimpala]xframeimpala.com[/URL" TARGET=_blank>
68 4x4 short fleetside deluxe cab 327 air [URL=http://www.xframeimpala.com/68]www.xframeimpala.com/68</A>
56 big window short stepside
64ImpalaSS 327 700R4
67 1 ton dually 157" wheelbase 327 SM420
ImpalaSS is offline   Reply With Quote
