New Member
losing coolant ,dont know where
Guys i need some help,i have a 03 gmc sierra with a 5.3 vortec and i started smelling coolant not inside the truck but outside and the coolant low coolant alert came on finally,problem is i see no leaks on the ground or on the motor could it be a head gasket,someone told me no water pass through the intake gasket so i ruled that out.What do you guys think.
Re: losing coolant ,dont know where
You need to have someone pressure test the system. Any corner repair shop should be able to handle this for you. Its up to you wether you'd like them to fix it for you or not.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
![]() Join Date: Sep 2005
the water pump gaskets are bad about leaking and burning off before it gets to the ground
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
have you filled it again and had the light come on again? might have just been some hard driving?
2001 Tahoe 1978 K30 |
New Member
You guys got it right again ,water pump leaking ,getting it fixed and everything should be good.
