Old 04-22-2012, 05:13 PM   #1
mooseknuckles
mooseknuckles's Avatar
brake switch?
has anyone got any info or diagrams on how to wire the 4-pin brake switch up?
mooseknuckles is offline   Reply With Quote
Old 04-22-2012, 08:45 PM   #2
clinebarger
Re: brake switch?
If you need to know what pin on the PCM....I need to know what year PCM your using.
clinebarger is offline   Reply With Quote
Old 04-22-2012, 08:52 PM   #3
mooseknuckles
Re: brake switch?
my harness has a purple (brake signal tcc ground) wire thats supposed to go to a 12v (brakes not applied)?
Old 04-22-2012, 09:11 PM   #4
clinebarger
Re: brake switch?
Hook the purple wire to the "to PCM" terminal of the brake switch.
Old 04-22-2012, 09:13 PM   #5
mooseknuckles
Re: brake switch?
thanks....that seems simple enough......lol..do you have a part # for the switch?
Old 04-22-2012, 09:36 PM   #6
TopFuel1966
TopFuel1966's Avatar
Re: brake switch?
http://www.summitracing.com/parts/PRF-80176/
TopFuel1966 is offline   Reply With Quote
Old 04-22-2012, 09:38 PM   #7
clinebarger
Re: brake switch?
AC Delco part# D862C
Old 04-23-2012, 02:10 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: brake switch?
oh no I tcc wires backwards
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-23-2012, 07:09 AM   #9
mooseknuckles
Re: brake switch?
thanks!....
Old 04-23-2012, 09:40 AM   #10
mooseknuckles
Re: brake switch?
I cant get that pn#...so I got a ac#d850a
Old 04-23-2012, 09:55 AM   #11
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: brake switch?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-23-2012, 10:25 AM   #12
mooseknuckles
Re: brake switch?
another question.....I have a orange wire for park/neutral, it says to ground (in park/neutral)....where does that go??
Old 04-23-2012, 12:13 PM   #13
ls1nova71
ls1nova71's Avatar
Re: brake switch?
This is why it's easier to leave the range sensor on the side of the transmission, it has switches that go to ground in park and neutral, and the NSS in older cars don't multi-task very well. But since you don't have it, and your harness is set up like an F-body LS1, you'll either have to just permanetly ground it (not the best option, but people do it), or put some kind of micro switches that will close in both ground and park, with one side wired to ground and the other side going to your PCM. Or, you could get away with using only one in the park position. Or, if you're feeling really ambitious, you can do this. http://ls1tech.com/forums/conversion...-question.html It works just like factory with only the original NSS.
Edit: as I was posting this, I remembered your truck isn't a 67-72. Some of the later trucks have a mechanical neutral safety switch, meaning that the key won't physically turn in any gear but park and neutral, it doesn't cut the electrical power to the starter solenoid. If this is how your column is, it will have a switch on the column, 2 wires will be for the back up lights, if it has another set, you could use them for your park/neutral switch. You'll have to check to be sure that they work that way on your year of truck, but I know that S-10's from at least '87-'94 are this way.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-23-2012, 05:41 PM   #14
softballnrd27
Always a work in progress
softballnrd27's Avatar
Re: brake switch?
Do I need the TCC brake signal for a th350 w/ a non-lockup converter?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-23-2012, 06:27 PM   #15
mooseknuckles
Re: brake switch?
thanks....yeah mine has a neutral saftey switch on the colum...I never really looked at it that close to see where i can hook it up...just want to be sure...
Old 04-23-2012, 06:32 PM   #16
mooseknuckles
Re: brake switch?
my truck already has a 4 pin switch, but I changed it to the new one anyway...it already has four wires hooked up to it, so do I just tie into that last wire?
Old 04-23-2012, 08:54 PM   #17
clinebarger
Re: brake switch?
I dont know what year truck you have...
The Pink wire will be the Ignition Hot...Leave it alone, Cut & splice onto the other wire. The polarity doesnt matter.
Old 04-23-2012, 09:16 PM   #18
mooseknuckles
Re: brake switch?
i dont know what year truck you have...
The pink wire will be the ignition hot...leave it alone, cut & splice onto the other wire. The polarity doesnt matter.
86
Old 04-28-2012, 08:01 PM   #19
mooseknuckles
Re: brake switch?
mine has a light blue and brown wire....
Old 04-28-2012, 08:34 PM   #20
clinebarger
Re: brake switch?
From the diagrams I have The brown will be the power wire, The blue wire is the one you need to splice onto.
Verify power at the Brown wire with the key on.
Old 04-28-2012, 08:52 PM   #21
mooseknuckles
Re: brake switch?
I was going to try that with a test light, but then I got sidetracked.....thanks alot man!
Old 05-08-2012, 11:28 PM   #22
Groyd
Groyd's Avatar
Re: brake switch?
Any chance I could see how the switch is mounted? I'm trying to figure out how to fit it on an s10 brake pedal assembly in a '51.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
