04-24-2012, 05:34 PM | #1 |
?? what is this rear from?
I'm told this is a posi rear end on one of my chassis. I'm not sure what it is from and i can't get a good match off the codes. any one know?
04-24-2012, 08:32 PM | #2 |
Re: ?? what is this rear from?
looks like its out of a 64 and older impala or biscayne
04-25-2012, 12:44 AM | #3 |
Were those a posi rear?
Posted via Mobile Device |
04-25-2012, 03:42 AM | #4 |
look on passenger side axle tube close to brake backing plate. scrape off all da crud - should find a set of numbers and letters . look under gm axle codes - should tell ya what ya need to know - hope this helps
04-25-2012, 07:58 AM | #5 |
ss impalas could come with a posi i know.
04-25-2012, 08:49 AM | #6 |
and a few others
Try posting over on the "engine & drivetrain" section of this forum.
Here: http://67-72chevytrucks.com/vboard/f...splay.php?f=24
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
04-25-2012, 09:09 AM | #7 |
58-64 full size car, some were used earlier but idk what years, corvettes also used these. If it were a factory posi it would have a giant "P" next to the casting numbers like in this pic i borrowed from egay. Search for "P case" and you will see plenty of them for sale. The date code should read similar to C221 like this one on egay (1961).
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
04-25-2012, 09:46 AM | #8 |
The housing looks to be 58/64 as a couple of the guys said because you can see where the suspension brackets were cut off.
It would cost you a gasket and some gear lube but I'd just pop the axles out and drop the pumpkin out and take a good look at it. To see if it is a posi, what gears it has and what shape it's in. Then you will know where you are at on all three things. Third members and gears got switched around in those rear ends on a regular basis so it may not have what it came from the factory with. I did pretty much the same thing when I converted my 48 to 5 lug in 1973. I bought a 61 car rear end from a coworker for 10.00 complete, pulled it out, trimmed the brackets off with a torch at work and had my buddy weld the spring pads on at his place. |
