Joining this croud with an 03 1500 HD
So after Thursday I should be joining the '99+ croud with a 2003 crew cab 1500HD. 119,000 miles with 3.73 gears and the 6.0 litre.
![]() Posted via Mobile Device
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
Re: Joining this croud with an 03 1500 HD
You know were going to want pic's right
![]() The 1500HDs are usually hard loaded LT's, Is yours? |
Hard loaded?
Just finalized everything today and not a moment too soon! My 1994 k1500 had the passenger side head gasket let go, and while switching stuff over i noticed more rust. https://skydrive.live.com/redir.aspx...DwCv-MWkNdNZg8 https://skydrive.live.com/redir.aspx...IYYotM7f-qjb1c Posted via Mobile Device
#4 | |
Just the power/heated mirriors with turn signals. Controls on the steering wheel too.
Vintage 4x4s
Those are nice trucks, and seem to always be in demand (1500hd's). Nice truck.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Thank you, and yes they do seem to be in high demand. I actually stumbled across this one when looking at a 2004 straight 1500. The salesman thought I was crazy for wanting the 1500HD(118,000 miles) worse than the straight 1500(65,000 miles), but after I explained to him why I think he understood better.
#8 | |
here is what it has for options when i ran the vin number. UB0 RADIO AM/FM STEREO,SEEK/SCAN,CD,AUTO TONE,DATA RAD STEREO W/CD & DATA RAD(UB0) UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3) UQ3 SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3) UY2 PROVISIONS, CAMPER WIRING HARNESS CAMPER & 5TH WHEEL WIRING HARNESS(UY2) VB3 BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME) CHROME STEP BPR(VB3) VG3 STRIP,FRONT BUMPER IMPACT FRT BPR IMP STR(VG3) VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4) VXS VEHICLE - COMPLETE V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) XGK TIRE FRONT LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(XGK) X88 CONVERSION CHEVROLET CHEVROLET(X88) MARKET BRAND CHEVROLET CHEVROLET(X88)(EXPORT) YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3) YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6) YE9 CONVENIENCE PKG COMFORT & DECOR LEVEL #3 COMFORT & CONVENIENCE PKG #3(YE9) YGK TIRE REAR LT245/75R16/E BL R/PE ST OOR(9591214) TIRE(YGK) ZGK TIRE SPARE LT245/75R16/E BL R/PE ST OOR(9591214) SPARE TIRE(ZGK) ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1) Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82) Z85 CHASSIS PACKAGE,INCREASED CAPACITY CHAS PKG(Z85) 1SB PACKAGE-OPTION 02 (1SB) 1SZ PACKAGE OPTION- (1SZ) 50U EXTERIOR COLOR ,PRIMARY,OLYMPIC WHITE (50U) EXTERIOR COLOR,PRIMARY (50U) PRIMARY COLOR EXTERIOR, OLYMPIC WHITE (93) (50U) 6GL SPRING COMPTR SELECT FRT LH SUSP(6GL) 69D TRIM COMBINATION CLOTH,VERY DARK PEWTER (69D) 69I INTERIOR TRIM COLOR,VERY DARK PEWTER (69I) 7GL SPRING COMPTR SELECT FRT RH SUSP(7GL) AE7 SEAT,FRT SPLIT,EASY ENTRY EASY ENTRY SPLIT F/SEAT(AE7) AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1) AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1) AM7 SEAT,REAR FOLDING RR FLDG ST(AM7) AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0) AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31) B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30) B32 COVERING,FLOOR MATS,FRONT AUXILIARY FRT AUX FLR MATS(B32) B33 COVERING,FLOOR MATS,REAR AUXILIARY RR AUX FLR MATS(B33) B71 ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BLACK) W/H MLDG(B71) ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(COLOR) W/H MLDG(B71) B85 ORNAMENTATION,EXTERIOR,BELT REVEAL MOLDING BELT RVL MLDG(B85) CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2) CMD PLANT CODE FLINT, MI, GM T&B FLINT, MI PLANT CODE(CMD) C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) C6P GVW RATING 8, 600 LBS/3, 900 KG 8600 LB/3900 KG GVWR(C6P) DF5 MIRROR,INSIDE,REARVIEW,LT SENSITIVE,COMPASS,O/S TEMP DISPLAY I/S REARVIEW MIR W/COMPASS(DF5) DK7 CONSOLE ROOF INTERIOR,CUSTOM,COMPASS & OUTSIDE TEMP RF CNSL(DK7) DL3 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, TURN SIG IND, LT SENSITIVE, COLOR ELEC HEATED O/S MIR(DL3) E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63) FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9) FT2 ARM TORS BAR SPRING ADJ (FT2) ARM LH TORS BAR SPR ADJ(FT2) FT3 ARM TORS BAR SPRING ADJ (FT3) ARM RH TORS BAR SPR ADJ(FT3) GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4) JH6 BRAKE HYD POWER, 4 WHL DISC, 9,900 LBS BRK HYD PWR DISC(JH6) KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP) KUP THROTTLE CONTROL VARIABLE SPEED (ELECTRONIC) ELECTRONIC THROTTLE CONTROL(KUP) K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) K47 AIR CLEANER HIGH CAPACITY HI CAPACITY A/CL(K47) K68 GENERATOR,105 AMPERE 105 AMP(K68) LQ4 ENGINE GAS, 8 CYL, 6.0L, MFI 6.0U(LQ4) MT1 TRANSMISSION,AUTO,4-SPD,THM-R2(4L80-E) 4-SPD A/TRANS(MT1) NA4 EMISSION SYSTEM,ABOVE 8500 LB GVW EMIS SYS(ABOVE 8500 LB GVW)(NA4) NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5) NP8 TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL TRANSFER CASE(NP8) NT9 EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT TIER 2 PHASE-OUT FED EMIS(NT9) NZZ PACKAGE,OFF ROAD SKID PLATE,SPORT SKID PLT PKG(NZZ) PDD CONTROL - SALES ITEM NO. 121 PY0 WHEEL,16 X 6.5,ALUMINUM ALUM WHL(PY0) QIW TIRE ALL LT245/75R16/E BL R/PE ST TL OOR TIRE(QIW) TIRE ALL LT245/75R16/E BW R/PE ST TL OOR 120Q TIRE(QIW) R9U CONTROL - SALES ITEM NO. 95 R9Z CONTROL - SALES ITEM NO.100 SLM SALES PROCESSING - STOCK ORDERS TR3 GRILLE RADIATOR, BODY COLOR, W/CHROME EMBLEM BODY COLOR GRILLE W/CHROME EMB(TR3) T96 LAMP,FRONT FOG FRT FOG LP(T96)
