05-02-2012, 12:58 AM | #1 |
Fuel Pump ?
I'm putting a LS2 in my project.
What is the best external fuel pump and filter to use? Do I need to do anything special as there is no return line from the engine back to the tank? This is all new to me and I don't want to screw it up. Kim |
05-02-2012, 08:29 AM | #2 |
Re: Fuel Pump ?
Run an external 255lph Walbro pump and get a filter/regulator for a 99-04 Corvette.
05-02-2012, 12:03 PM | #3 |
Re: Fuel Pump ?
The corvette filter/regulator has a return line built in. So you will have to run return line back to the tank. But the walboro and vette filter works good as stated above.
Posted via Mobile Device |
05-02-2012, 12:15 PM | #4 |
Re: Fuel Pump ?
I am about to cross this bridge as well. What filter do you guys recommend
if you have a return style fuel rail ? Also are you running a filter before the pump or just after? Thanks. |
05-02-2012, 03:59 PM | #5 |
Re: Fuel Pump ?
Thanks for the info guys I appreciate it.
Kim |
05-02-2012, 07:22 PM | #6 |
Re: Fuel Pump ?
whalbro 255 and wix 33737
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
05-02-2012, 07:49 PM | #7 |
Re: Fuel Pump ?
Thanks for the pics mooseknuckles.
Kim |
05-02-2012, 10:24 PM | #8 |
Truck and auto performance nut
Re: Fuel Pump ?
Hey that resembles my setup! My Vette/Wix filter/reg is on the inside tho. I like your fuel pump brackets better...had to make mine from scratch and that's all I had. Guess I could trim it tho.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-02-2012, 11:49 PM | #9 | |
Re: Fuel Pump ?
Kim |
05-03-2012, 12:56 PM | #10 |
Re: Fuel Pump ?
there's a big Trick Flow aluminum canister pre-filter, then the Walbro pump, then and a Vette filter/regulator with a return line. Just filtering before the pump to keep it clean and the filter/regulator setup takes care of the fuel pressure and provides the return path...and post-filter capability. overkill????
05-03-2012, 04:19 PM | #11 | |
Re: Fuel Pump ?
Kim |
05-04-2012, 08:42 AM | #12 |
Re: Fuel Pump ?
Ebay E2000 pump here with said vette filter/reg and I run a filter before the pump too.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
05-04-2012, 06:03 PM | #13 | |
Re: Fuel Pump ?
If it's an aftermarket billet rail, run the vette filter and cap off one end of your fuel rail. If it is a stock rail, run the return line back to the tank.
'55 3200 283 4 speed '68 Pontiac Firebird Poncho powered with a 6 speed |
05-17-2012, 10:10 PM | #14 |
True Addiction
Re: Fuel Pump ?
Hey Guys,
I am haven't been able to confirm the correct fitting needed for the out flow to the motor side of the filter. I had thought it was a 3/8" outlet. Is this it by chance? http://www.summitracing.com/parts/RUS-640940/
RCC |
05-21-2012, 12:05 PM | #15 |
Re: Fuel Pump ?
Are the external pumps known to last long?
05-21-2012, 12:44 PM | #16 |
meowMEOWmeowMEOW
Re: Fuel Pump ?
too broad of a question. Short answer is yes, they work fine and if setup correctly there should be no issues with them lasting.
05-21-2012, 06:10 PM | #17 | |
Re: Fuel Pump ?
05-21-2012, 06:14 PM | #18 |
Re: Fuel Pump ?
my whalbro pump is at the back of the cab...should I move it closer to the tank??...I've heard of these pumps being better "pushers" than "pullers"?....
05-21-2012, 06:33 PM | #19 |
Re: Fuel Pump ?
external pump should be as close to the tank as possible....yes better pushers.
05-21-2012, 08:45 PM | #20 |
Re: Fuel Pump ?
If you use any quick connect fittings, make sure you get the newer ones that have the C-clip instead of the plastic retainer, the ones with the plastic retainer have been known to come off under preasure. Heres the link to a post I did about the fittings http://67-72chevytrucks.com/vboard/s...d.php?t=502781
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
05-21-2012, 10:22 PM | #21 |
True Addiction
Re: Fuel Pump ?
Awesome, order yesterday. Thanks Moose
RCC |
