Old 05-06-2012, 04:33 PM   #1
Baconfuel
Question 2004 chevy rear end bent
I have had this truck for 8 months and put 10k on it and now I'm on my third set of tires.
They only wear on the inner tread. Completely bald.
I took it to BeeLine Auto here in Columbus Ohio and was told the housing has been bent.
My question is which Chevy rear end years are compatible?
Have not got much help from junkyards. I want to keep my disk brakes and wondering what works for a straight swap?
Thanks JHT67 for telling me about this sight. It's sweet. Hope you and your dad enjoy the GMC.
Baconfuel is offline   Reply With Quote
Old 05-06-2012, 06:17 PM   #2
clinebarger
Re: 2004 chevy rear end bent
1500, 1500HD, 2500HD, 3500?
Gas, Diesel?
Fill out you Signature so everyone knows what you have.
clinebarger is offline   Reply With Quote
Old 05-06-2012, 09:31 PM   #3
Baconfuel
Thanks. I will fill out my signature.
It's a 2004 Silverado 1500 2wd V6 4.3l 8 ft. bed.
Old 05-06-2012, 09:44 PM   #4
clinebarger
Your stuck with a 99-04 8.6" 10 bolt, Do you know the gear ratio?
Old 05-06-2012, 09:49 PM   #5
Baconfuel
No go on the ratio.
Is it stamped somewhere on the housing what the ratio is?
2004 Siverado 1500 4.3 2WD
Old 05-07-2012, 07:42 PM   #6
67mater
67mater's Avatar
Glove box RPO codes should give you the ratio. With 2WD you dont need to match a front axle, so that frees you up on ratio.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 05-07-2012, 08:45 PM   #7
clinebarger
Going to a different ratio will throw the speedometer off. And the shift points on a auto.
Old 05-07-2012, 08:52 PM   #8
71swb4x4
71swb4x4's Avatar
Why does it mess up the shift points on the transmission? I am not saying you are wrong, just never heard of that. I assume it has something to do with the newer transmission but if you would explain that would be great. I always thought the transmission shifted based on RPM's.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-07-2012, 09:27 PM   #9
clinebarger
The VSS sensor reads driveshaft speed, The PCM uses the vehicle speed signal to determine shift timing and TCC scheduling. Other contingencies play a role as well, such as throttle position, and transmission temperature to determine actual shift timing.
Older transmission used a governor to do the same thing, And they need to be recalibrated to correct shift timing of the rear ratio is changed.
Old 05-11-2012, 12:41 PM   #10
crazy longhorn
Fabricate till you "puke"
I just swapped a 3.73 under my 02, inplace of a 3.42....as stated, the speedo is a tick off, & the shift points are a little different. Other than the speedo reading 4-5 mph fast, it hasnt seemed to be a problem? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-12-2012, 07:22 PM   #11
Baconfuel
I found a rearend here in Ohio. 70k on it with 6 month warranty for $500. Does this sound like a fair price?
Old 05-12-2012, 07:46 PM   #12
clinebarger
Sounds fair, 6 month warranty is really good, Most places give a 30 day warranty on used parts.
rear end. 2004 silverado
