Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 73-87
Closed Thread
Old 03-16-2012, 11:01 PM   #1
esbstuff
Re: 81-87 bumper on 74?
To read the original thread and discussion on this topic go here- LINK
THERE IS NO NEED TO CUT FRAMES< NEVER!!!! Do I need to say that again? NEVER!!!!!!!
To install a 81-91 bumper on a 73-80 frame, all you have to do is make one VERY SIMPLE (2 min hacksaw) cut on the 81-91 center bumper bracket and the bumper is a bolt on! Yes BOLT ON!
All you have to do is cut the center bracket along the crease on a diagonal. On the end brace the center hole (in between the the 2 welded on nuts that are usually used) is the very same hole that the 73-80 end brace uses.
I really don't how to explain this so I take a photo in the morning to show were the cut is made.
But to say this a third time, THERE IS NO NEED TO CUT FRAMES< NEVER!!!!
esbstuff is offline
Old 03-31-2012, 01:11 AM   #2
esbstuff
All right here is the pictures... The first shows a stock bumper bracket, the second is where you need to make the cut (RED LINE). Throw the smaller piece away and bolt-on the larger piece to your truck. Then bolt the 81-91 bumper on.
I have done a dozen or so and there is nothing else to do, nothing!
PS... Sorry to those of you that have cut and wacked your frames, the conversion is just this simple.
esbstuff is offline
Closed Thread
