05-08-2012, 12:49 PM | #1 |
xmember sand blasting cost
I've got my xmember disassembled and am about to get everything blasted.
xmember, upper and lower arms, centerlink, spindles- I have never got any prices before, I was curious what would be an acceptable price range to have this done. Any insight would be greatly appreciated. - thanks in advance |
05-09-2012, 10:16 AM | #2 |
Re: xmember sand blasting cost
We blasted our entire frame over about 6 hrs using 350 pounds of sand in a 30lb sandblasting pot, and maitaing 90psi at the pot. If you have the place and a compressor able to handle the supply I suggest renting a pot from the local tool rental store. We borrowed ours from a friend. I would think just doing a front cross member you could do it yourself for under $50 renting the blaster.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
05-09-2012, 02:16 PM | #3 |
yea...I can't blast anything bigger than a valve cover at home.
05-10-2012, 07:25 AM | #4 |
All i can tell you is call around a few places and see what they will charge you.
05-10-2012, 09:15 AM | #5 |
ok- thanks guys- I just didn't want to hear a place say $150 only to find out that the normal charge would be around $50.
I guess I'll start shopping around. |
