grounds
where are you guys putting your main ground from battery? Originally on block.
![]() Join Date: Dec 2007
Re: grounds
I bolted mine to the font of the passengers side head.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: grounds
Mine is bolted right on the motor mount perch, at the frame. then I ran on #8 from there to the cab, where the heater mounts are, just so they motor ground on the rear of the motor would have the best ground
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: grounds
my battery's in the back, so ground from batt goes to frame, one from motor to frame, one from frame to cab, and one from motor to cab....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
Re: grounds
ok. mine was originally bolted to the block and i was making sure i should put it back there.
![]() Join Date: Nov 2007
Re: grounds
I ran two big grounds. One over the drivers side and bolted to the block at the OE location. The other goes down to the passenger side frame rail.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Truck and auto performance nut
Re: grounds
I wouldn't think an aluminum head would be my 1st choice. My battery ground and efi system main ground go to the block (fr&bk). Block to frame, frame to cab and frame to bed.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: grounds
I haven't had any problems with my ground connected to the aluminum head verses the cast iron block. Not all blocks are cast iron, some are aluminum.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2002 Winnebego Class A MH Ford E-550 Chassis V-10 2005 Dodge Ram 2500 5.9 Cummins 2008 GMC Denali 2020 Jeep Wrangler Unlimited Rubicon Last edited by awhite4557; 05-17-2012 at 09:54 AM. |
