Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-15-2012, 10:20 PM   #1
72chevynoob
Why does my sub squeak?
I have a clarion sub (not new) that came with my truck. It makes ok bass but squeaks like crazy. Why is this?
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 05-16-2012, 04:43 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Why does my sub squeak?
The only part I can think on a speaker that can cause a "squeak" is I think the voice coil (or maybe it's the motor) contacting at movement. Does it squeak if you just push the speaker in without it on?
The only other thing is maybe it's more of a whistle coming from a port?...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-16-2012, 09:40 PM   #3
RRR18
RRR18's Avatar
I'm just guessing....someone got the voice coil a little hot. I've had older subs react weird to extreme heat and or extreme cold. Of course that's after I've beaten the piss out of em.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 05-16-2012, 11:39 PM   #4
72chevynoob
So...its shot? Or could checking for air leaks whistling fix it? It doesnt squeak when I pjsh it in manually.
Justin
Old 05-17-2012, 05:36 PM   #5
bigwheel15
bigwheel15's Avatar
Pull the sub out of the box and play it, does it still squeak? If it does there is possibly an issue with the sub. If not air is leaking from the box/around the mounting surface of the sub.
bigwheel15 is offline   Reply With Quote
Old 05-17-2012, 06:00 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Ditto...but more than likely it's the sub's voice coil's going out and time for a replacement. If you have anyone with the same size sub it'd be worth even popping it in to see if the squeek goes away.
1970 2wd Blazer
Old 05-17-2012, 11:27 PM   #7
AceX
>130dB Moderator
AceX's Avatar
My guess is the gasket around the mounting ring of the sub is going bye bye. I have the same issue on my Arc Audio subs in my '85.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 05-18-2012, 06:25 PM   #8
Normru45
sounds like a air leak or the wood in the box is moving, i would not think i would come from the sub. good luck
Normru45 is offline   Reply With Quote
Old 05-21-2012, 06:40 PM   #9
AceX
>130dB Moderator
AceX's Avatar
I've heard it come from the voice coil before. My suggestion towards the issue simply implies non-catastrophic issues (Read: hoping for the best)
Living Life @ 130dB
RIP El Jay
Old 05-21-2012, 07:13 PM   #10
72chevynoob
Thanks for all the input, guys. I sealed around the sub and it still squeaked, so i felt for an ait leak and found a monster one between the metal center and the rubber surrounding it. I sealed that with clear silicone, and now it kicks with no flutter or squeakiness at all.
Justin
Old 05-22-2012, 12:13 PM   #11
tubbedII
needs more $$$
tubbedII's Avatar
Great news! I hope that silicone lasts...I've never had good luck repairing a speaker cone.
1970 2wd Blazer
