Old 05-21-2012, 03:08 PM   #1
mklomps
59 fleetside hood hinges
hood hinges are loose. when under hood the just arent tight enough to hold the hood up. already replaced the springs but that didnt help.
mklomps is offline   Reply With Quote
Old 05-21-2012, 08:17 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 59 fleetside hood hinges
did the same with mine. New springs did not help.
Best thing I did was buy a repop set no more troubles. You can get the originals rebuilt but it can be expensive.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-21-2012, 08:40 PM   #3
Rude Dude
Rude Dude's Avatar
This is temp fix if you have torches heat at the swivel points until cherry red and blandish them with a 5 pound sledge against a solid metal surface, it works til you can afford new ones. I think if you post on the other section you might get more responses then the build section.
Rude Dude is offline   Reply With Quote
Old 05-22-2012, 09:57 AM   #4
mklomps
thanks guys and im sorry for posting in wrong place
