Old 05-23-2012, 01:23 AM   #1
Mike Honcho
Mike Honcho's Avatar
6-lug disks?
Anyone ever re-drilled a 5-lug disk rotor to the six lug pattern? I took a 5-lug rotor from a 72 with no wheel studs in it and sized it up to a 6 lug wheel today. If the holes were welded up it looks like the 6 lug pattern would fit. I was just wondering if this was do-able. Any of you guys tried this before? I would like to stay with the 6 lug wheels on my 66 and just thought this might be a cheap alternative to aftermarket rotors as i already have all the parts from a donor truck.
Mike Honcho is offline   Reply With Quote
Old 05-23-2012, 03:57 AM   #2
Woogeroo
Re: 6-lug disks?
What wheels are you running?
I think there is a clearance issue with the original stock 15 inch steel wheels in six lug if you go to discs. I think the caliper hits the inside of the wheel or something.
http://www.earlyclassic.com/
sells parts for 6 lug disc swaps tho'.
-W
Woogeroo is offline   Reply With Quote
Old 05-23-2012, 09:25 AM   #3
Raked 64
Raked 64's Avatar
Talking Re: 6-lug disks?
I am about to swap from 6lug disc brakes to 5 lug. I have a classic performance kit on the truck with zero miles. Send me a PM and maybe I can help you out reasonable.
Raked 64 is offline   Reply With Quote
Old 05-23-2012, 05:01 PM   #4
theastronaut
theastronaut's Avatar
Re: 6-lug disks?
I've got 6 lug disc on my '66 and it takes a 1/4" spacer for the original wheels to clear the calipers.
theastronaut is offline   Reply With Quote
Old 05-23-2012, 08:18 PM   #5
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: 6-lug disks?
I think the square body 4x4 disc are 6 lug. This is a pic I took from Autozone web site: $39.99
http://www.autozone.com/autozone/par...6_172979_2708_
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 05-23-2012, 08:36 PM   #6
tincan1966
tincan1966's Avatar
Re: 6-lug disks?
Buying rotors that fit is cheaper than paying someone to weld up a used set and re-drill. In my opinion, anyway, because everytime you needed one, you'd be going thru the same process.
tincan1966 is offline   Reply With Quote
Old 05-24-2012, 12:24 AM   #7
Captainfab
60-66 Nut
Re: 6-lug disks?
The options for 6 lug front discs have been discussed in this thread a few times.
http://www.67-72chevytrucks.com/vboa...d.php?t=367260
Old 05-24-2012, 12:43 AM   #8
1enick72
1enick72's Avatar
Re: 6-lug disks?
Drilling your own holes may sound cheap but if they are not exact your tires will never be balenced.
1enick72 is offline   Reply With Quote
