Old 05-23-2012, 11:55 AM   #1
MAK191
Starter and Alternator question
So, my 2002 5.3 (from a Yukon) came with everything except a starter and alternator. I do not have the VIN, my computer came from a different truck so I can't decode. As I search online for a replacement I have found a couple options (there may be more).
Alternators
105 amp
130 amp
145 amp
Question : Which one to get, will the 105 amp be adequate with E-fans? Ive heard they need extra power. Is this true?
Starters
9 tooth
11 tooth
And 1-2 kw
Question: I have no idea how to figure out what I need.
Thanks for any help
-Mike
MAK191 is offline   Reply With Quote
Old 05-24-2012, 03:03 AM   #2
BigDan3131
BigDan3131's Avatar
Re: Starter and Alternator question
First question I have is what is this going in to and second have you added up all the amps that you will draw with the vehicle running? Do you plan to add a stereo system with big amps? As far as the starter goes I would ask the local chevy dealer parts counter or google which starter was used on that yukon.
BigDan3131 is offline   Reply With Quote
Old 05-24-2012, 12:00 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Since there isn't a ton of electrical draw on these trucks, the 105 would get you by. The alt on my sbc was only 85amp and did just fine. Add in things like modern lighting, stereo and fuel injection and even then the 105 should be ok.
Fwiw, I ended up getting a 145 since it's what came with my bracket....and there's no way I'll ever come close to using that much amperage. They also made a 160amp on certain HD's and Express vans.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-25-2012, 11:09 PM   #4
MAK191
Thanks guys for the input. I guess I made this more complicated than it needed to be. I just wasn't sure if you could just put a higher rated alternator without problems. From what I have found you can go up to a 145 amp without having to change the wiring. I will probably just get the 130 cause it is priced right.
Old 05-26-2012, 10:28 AM   #5
mooseknuckles
mooseknuckles's Avatar
...so is there a way to tell alt. apart by looking at them?...my lq4 was out of a chevy express van.....
mooseknuckles is offline   Reply With Quote
Old 05-26-2012, 03:18 PM   #6
MAK191
I was at the local pick a part today and looked at a GM alternator and it had a label on the back with the part number and 105A, so I assume many had labels at one time. Also, in my research the clock position of the connector is different. Same connector just different position.
