High Idle
2001 5.3 Silv. truck runs great but has a random high idle usually when it is hot outside .Truck will run a high idle around the 12000 rpm range I was thinking the IAC solonoid ??I have pulled the egr and the IAC off and cleaned it with carb cleaner but no help.Should I replace them ?No codes are stored
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Jan 2003
Re: High Idle
12000 rpm is a little more than a high idle,
![]() Check for air leaks and the IAC
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
