reverse manual valve body
does anyone on here run reverse valve body on the steering column? i have a b+m pro stick and a bench seat and the shifter is way to low. i started to make a console but it looks crapy.. any ideals
Re: reverse manual valve body
I would try and make a riser for your shifter. I ran a standard pattern valve body on the column for several years and it was kind of a pain. The ratchet style shifter is much better way to go imo. You don't have to worry about going into the next gear. You could always get a B&M Mega Shifter for trucks with a higher base. That's what I have and it works good.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
thanks for the info redsled87, ill check out the mega shifter, i'm thinking of trying to fab a mount off the seat frame but that would bring the cable way up off the floor . dang if you do,dang if you don't
mine sat too low as well so i made this fully adjustable platform for the shifter to get it up higher. you might be able to do something similar. mine has a tci manual forward valve body.
I also made a riser to get the shifter to were i was comfortable .
![]() Thats a wild looking riser dbmx66.
Brandon Street Car Mafia |
thanks for the pictures guys , those are nice, im going to scrap what ive been working on today and make one similiar to yalls. heres a pic of what i wasted my time on
I want to put a cage in my son's truck and build a shifter mount off the dash bar. I have seen a sexy one on here that someone built.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
mini truck racer
This is one that was in my Foxbody . Just to give an idea .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
