06-10-2012, 04:31 PM | #1 |
steering wheel questions
I have this 63 impala steering wheel that comes up a bit far to me when Im driving I would like to change it to a less dish even a flat wheel so it don't seem so tight in the cab for me any thought?
06-10-2012, 05:14 PM | #2 |
Re: steering wheel questions
I have 2 ideas for you.
First, collapse the column. I did mine in one morning, gave me around 1.5 - 2 extra inches, real easy to do http://67-72chevytrucks.com/vboard/s...d.php?t=191143 Here is a link to steering wheel resizing, you can use same idea to flatten as well, gonna do that too someday http://67-72chevytrucks.com/vboard/s...d.php?t=457422 Although your horn ring would make this more complicated, you would have to rework it and have it rechromed or something... hope this helps
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
06-10-2012, 09:33 PM | #3 |
great write up on the steering wheel shortening, but I've told that the one I have can not be shortened Pls take a look at the pics Thanks
06-10-2012, 09:39 PM | #4 |
oops heres the pics
06-10-2012, 11:02 PM | #5 |
Whats the column out of...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
06-10-2012, 11:03 PM | #6 |
not sure exact vehicle 63 impala?
06-10-2012, 11:55 PM | #7 |
I`m not sure but I think they started collapsable columns in `60 if so there is no reason you couldn`t that I can think of, maybe someone else knows.
06-11-2012, 12:38 AM | #8 |
It looks like the intermediate shaft (the black one) could be replaced with a 67-up shaft and do the shortening trick.
Wouldn't cost much at all (find one on the board here cheap) and give it a try... easy, and can be undone if I am wrong. I would sure try it...
06-11-2012, 11:58 AM | #9 |
Off topic but going to ask anyway,What did that seat come out of? Looks good!
Posted via Mobile Device |
06-11-2012, 12:45 PM | #10 | |
Whoa, there actually are other people as crazy as me. I cut down my '66 Custom wheel to 15", but kept spoke angles the same so I could keep my original horn ring. I doubt I'd do another though! I shortened the column 3" as well to give more room in the cab. 15" wheel resizing: http://67-72chevytrucks.com/vboard/s...d.php?t=517005
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-16-2013, 10:31 AM | #11 |
would 64- 65 Cadillac wheel be the same to install
12-16-2013, 10:54 AM | #12 |
Column is out of a 1964 impala, notice the trim piece does not fit the dash correctly,hangs below.
12-16-2013, 05:33 PM | #13 |
It looks like it is the front bench out of a 90's suburban. I bout one for my truck from a junk yard. The only problem is it is real hard to find replacement upholstery for them and the back does not tilt forward.
12-17-2013, 09:17 AM | #14 |
I used a 90's camero steering wheel in my 65...lots more room
