Old 06-16-2012, 04:46 AM   #1
hula
Where do I find a ring/pinion for K20 Eaton?
I have a 1968 K20 3/4 ton 4WD with an Eaton rear end. Where do I find new ring and pinion sets?
hula is offline   Reply With Quote
Old 06-16-2012, 06:41 AM   #2
Beersnob
Re: Where do I find a ring/pinion for K20 Eaton?
Call Randy's Ring and Pinion. They are located in Seattle and can usually get anything you want. Website is www.ringpinion.com. Phone is 1-866-631-0196.
Beersnob is offline   Reply With Quote
Old 06-16-2012, 11:27 AM   #3
BlackhillsHD
BlackhillsHD's Avatar
You are not going to find a new ring and pinion for an Eaton anywhere. Unless its a NOS on and you are going to pay through the nose for one. There is a thread over on Pirtate4x4 on the H072, and there is a company that is suppose to be producing them again soon. They are still in the development stages.
1970 : Chevy: K20 "Frank the Tank" 6.0 LS, 4L80E, 14 bolt, and Dana 44
1970 K5 Blazer CST 350, TH350, Np205, Dana 60 and 14 bolt
General Motors Master Certified wrench swinger
ASE certified Master auto tech
Instructor of Automotive Technology
BlackhillsHD is offline   Reply With Quote
Old 06-16-2012, 01:16 PM   #4
Redcap
Dump the Eaton and swap in a D60 or 14b.
Redcap is offline   Reply With Quote
Old 06-16-2012, 03:30 PM   #5
obijuan
Buy another axle. What ratio do you want?
obijuan is offline   Reply With Quote
Old 06-17-2012, 12:10 AM   #6
andrewmp6
I did a ton of googling i can't find anything for it.
andrewmp6 is offline   Reply With Quote
Old 06-17-2012, 06:15 AM   #7
Lots of fools do that. Just buy or let one of them give you the one they're dumping and use the parts. What's wrong with yours? These are great rears and seldom need ring & pinion replacement,unless not lubed properly. If you want to change ratios,same thing,find an axle someone is discarding. I love them and in over 30 years have yet to find a reason to dump one for a rear that it no improvement.
Old 06-17-2012, 03:49 PM   #8
hula
I have 4:56s and want a 3:73. I'll check Randy's and around.
Old 06-17-2012, 03:56 PM   #9
hula
What size is the ring is it 8.5? Mine is a 10 bolt round cover.
Old 06-17-2012, 07:49 PM   #10
obijuan
The 8 lug ho72 is a 10.5 ring gear or so. And 3.73 is not an available ratio. 4.10 was the highest, with 4.56, 5.13, and an alleged 5.86.
Old 06-17-2012, 08:27 PM   #11
mknittle
mknittle's Avatar
They are tough but the only ratios are slow and slower. ihave never seen a 4.10 I would like one. the only ones i have seen were 4.56and 5.13.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-17-2012, 10:24 PM   #12
BlackhillsHD
I have a 410 in mine
Old 06-17-2012, 11:51 PM   #13
hula
Great. Well I will be driving it around town anyway. Maybe a swap will be in the future. I don't think the swap to 4:10 will make that much difference anyway.
Old 06-18-2012, 01:41 PM   #14
hula
What year or model of rear end is a straight swap as far as spring perch and all?
Old 06-18-2012, 10:15 PM   #15
obijuan
If you've got leafs, 73-87/91 square body one tons. 2 and 4 wheel.
Old 06-23-2012, 10:12 AM   #16
hula
What about a Dana 60 for the rear since I have a Dana on the front? There's a Dana 60 rear on the forum. Parts easier to find, like ring and pinion?
http://67-72chevytrucks.com/vboard/s...d.php?t=488076
Old 06-23-2012, 11:07 AM   #17
obijuan
Meh, its a wash.
Old 06-23-2012, 02:43 PM   #18
hula
Obi, is that good or bad?
Old 06-23-2012, 03:44 PM   #19
obijuan
Most 8 lug rear axles.will provide long lasting service. Decide your parameters, like desired ration, original-ness, match front axle width, or just plain beef.
A 14 bolt is tried and true and cost effective. 373 is the highest ratio there with a matching front.
A 60 can get 355s, not sure about a 44.
