Old 06-17-2012, 09:50 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
what rear brake hose to use with lift
Ive just ordered 8' spring all the way around for my 68 they have extended front brake hoses but what am I to do with the rear? it has a 12 bolt rear, any suggestions? part numbers?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 06-18-2012, 10:57 AM   #2
obijuan
Re: what rear brake hose to use with lift
go to a local brake and hydraulic shop and get it made. bring your old one with you and tell them to make it longer.
obijuan is offline   Reply With Quote
Old 06-21-2012, 01:15 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
I like Kore3. I used them to build the ones for my Chevelle when I installed the C5 brakes...
Rich
1972 K5 Blazer CST Click HERE
Old 06-21-2012, 07:08 PM   #4
OrrieG
OrrieG's Avatar
I worked with Russell directly, I have 74 K10 axles on the 59 springs. I measured from the calipers in front to the fitting at the frame, and from fitting I located at the frame cross member above the axle to the stock Tee on the rear axle. Turned out a 4" lift kit for a 74 worked out ok. The tech I talked to was able to look up lines based on the length and type/size of fitting on each end. He also said it they did not work they would exchange them and pay the shipping. I've recommended them a bunch of times with no complaints I know of.
OrrieG is offline   Reply With Quote
Old 06-24-2012, 06:38 PM   #5
76stepsidechevy
I went down to my local napa and had them pull a stock one off the shelf and then find the same thing but 6" longer and they did. I think it was only like 15 bucks too.
76stepsidechevy is offline   Reply With Quote
Old 07-04-2012, 01:32 AM   #6
HEISEL
HEISEL's Avatar
if its not to late, brake line on 97 1500 chevy 2wd are 24" long. I had the same prob not to long ago. got the rear off a 1997 1500 2wd and the front are off a 77 3/4 ton 2wd. hope that helps.
1972 k/10 4x4 swb
2011 camaro SS/RS M6
HEISEL is offline   Reply With Quote
