Old 02-22-2002, 03:04 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
Post disc brakes & step bumper for 65 1/2 ton
I read the link below about 3/4 ton brake swaps but does that also apply for 1/2 tons ?
the link below said quote "not a myth, but you will also need tie rods, center link, ball joints and stuff from that year truck.... or just swap the entire front crossmember"
it seems that because these crossmembers are welded that it would be a lot of unecessary work to do that . Is there any advantage to changing entire thing . I already have a few 73-80- front ends/ .
I am also looking fro a 'BOLT ON" style rear step bumper for these trucks .
Who offers the best catolog for this style truck also . thanx for any help, DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 02-22-2002, 07:30 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
the front crossmembers arnt welded they are held in with about 6 bolts! and yes it also applys to 1/2s
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 02-25-2002, 04:57 PM   #3
jamiew
Post
Dave,
I changed the entire crossmember in my 64 and swapped it for a 76 model with disc brakes. It bolted up with little problems. there are 7 bolts that hold each side to the frame, 4 in the side of the frame, 3 in the bottom of the frame. All bolts lined up except the bottom two of the 4 side bolts, they are off about 1/16 of an inch. I just egged out the holes a little and the bolts went in perfectly. Very easy job and took only about an hour and I did it all myself. You will need to hit an alignment shop though before you do very much driving though. Have fun.
JamieW
jamiew is offline   Reply With Quote
Old 02-25-2002, 07:39 PM   #4
crossy
crossy's Avatar
Post
thank you ,excellent reply .
anyone on the step bumper? DAVE
98 Vortec project.
94,3500,6.5L 4L80
