Old 06-24-2012, 08:17 PM   #1
hula
Any difference in 68 and 69 rear end mountings?
I have a 68 K20 3/4 ton 4WD with an Eaton rear end. I want to use a Dana 60 out of a 69 3/4 ton chevy. I was thinking it should be a straight swap. Are there any differences between the mountings of the trucks?
hula is offline   Reply With Quote
Old 07-04-2012, 10:45 AM   #2
msgross
msgross's Avatar
Re: Any difference in 68 and 69 rear end mountings?
You'll have to measure the distance between leaf springs and the actual spring width itself... Keep as many parts from the 68 that you can... diy4x.com has cheap parts if you need to weld new perches to the newer axle...
I placed a 2WD posi axle under my 68 K10...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-05-2012, 06:50 PM   #3
Mike C
Mike C's Avatar
Is the '69 a 4x4 also? Should be 40.5" spring centers on 4x4 and on Longhorn with 2 1/2" wide springs. If it's on 2 1/4" springs and 2x4 will be 42.5" spring centers.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-05-2012, 09:21 PM   #4
obijuan
73-91 square body 1 ton 14 bolts are a direct swap.
obijuan is offline   Reply With Quote
