Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 06-25-2012, 11:34 PM   #1
Rgilbert
RPM's dip at idle and truck sputters on acceleration!
My 2008 4.3L silverado has been running rough the past few weeks, at idle the RPM's dip and the truck shakes every 10-20 seconds then returns to normal. When accelerating it jolts and sputters till it catches up then runs like normal above 1500 rpm's...What do y'all think could be the reason??
Rgilbert is offline   Reply With Quote
Old 06-26-2012, 12:13 AM   #2
Scotty-D
Scotty-D's Avatar
Re: RPM's dip at idle and truck sputters on acceleration!
Is the service engine soon light on? If so, does it blink when it's sputtering, and then quit blinking when it picks up?
85 Scottsdale LWB
383 227/235 105 lsa Howards Roller
TH350 by Jakes Performance, Sanger TX
Scotty-D is offline   Reply With Quote
Old 06-26-2012, 02:16 AM   #3
BigDan3131
BigDan3131's Avatar
How many miles are on it? Its either the fuel pump or the coil.
BigDan3131 is offline   Reply With Quote
Old 06-26-2012, 09:56 AM   #4
Rgilbert
One time when the problem first started the check engine light flashed about 5 or 6 times then went off and hasn't flashed again. There are only 41,000 miles on it.
Old 06-26-2012, 12:44 PM   #5
72chevyk10
I built it
72chevyk10's Avatar
i would say one of the plugs went bad or are not firing
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 06-26-2012, 01:35 PM   #6
storm9c1
*** That's interesting ***
storm9c1's Avatar
Agree. A flashing CEL (service engine soon light) usually means ignition misfire detected. Have the codes scanned. Chances are the codes will even tell you what cylinder was misfiring.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-26-2012, 04:21 PM   #7
Rgilbert
If it was a misfire why does it still run bad, like what is causing it? And how would the misfire problem get fixed?
Old 06-26-2012, 04:25 PM   #8
Rgilbert
I talked to a friend who is a mechanic and he said his truck was doing the same thing but it was from carbon build up in the throttle body...could this be a possibility?
Old 06-26-2012, 04:59 PM   #9
storm9c1
storm9c1's Avatar
Could be. Wouldn't hurt to spray it out with throttle body cleaner and/or use some Seafoam.
However, if CEL was flashing, that's an ignition system misfire -- something with the plugs/wires/coil, etc. Have the codes scanned by a parts store and see. No need to guess when your computer may tell you exactly what is wrong.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 06-26-2012, 05:24 PM   #10
72chevyk10
I built it
72chevyk10's Avatar
if a v8 is only runing on 7 you will always feel that "miss". my dads truck had a cracked spark plug that drove me and him crazy for a few months. would do exactly as you describe. test: plugs, wires, cap, and coil. and like storm said, a computer will probly tell you which cylinder is misfiring, if it is..
Old 06-26-2012, 06:25 PM   #11
Scotty-D
Scotty-D's Avatar
There are quite a few completely different things that will make it missfire. Like posted above, you will have to pull up the engine codes to see what you are dealing with.
With the sputtering at low rpm that you are describing, it sounds alot like a random multiple missfire to me. The only way to know for sure is to have it scanned and see what code(s) its throwing.
85 Scottsdale LWB
Old 06-27-2012, 12:18 PM   #12
Rgilbert
I will definitely see what codes it threw thanks for the help guys!
Old 06-29-2012, 12:10 PM   #13
bwood
bwood's Avatar
I may be wrong, but a flashing CEL is an indication that the PCM believes that damage is being done to the emission system (cat). This could be a misfire, poor or out of range O2 sensor signals, ect. Go by Autozone and have them check the codes for free then post them. I would check fuel pressure and make sure it is around the 60 psi range. I believe the V6 in your truck has had the same Vortec injection system since 96, they require 60-63 psi of fuel pressure. Also check the condition of the cap an rotor, 41k isn't many miles but it is 5 yrs old. Over time, the cap contacts corrode and cause similar issues.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 07-03-2012, 08:56 PM   #14
badpontiacs
badpontiacs's Avatar
I believe there is a special policy for that. Take it to the dealer or give me your VIN in a pm and i can run it to see if it applies. I am a GM tech at a local Chevy dealer.
badpontiacs is offline   Reply With Quote
