Upper radiator hose?
I am looking to replace my upper radiator hose on my 1967 k10 327. When I go to the parts store they try to give me a flex hose. I would like a one piece, moulded hose. If anyone has a part number that might work for my application, I would appreciate it.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
Re: Upper radiator hose?
I think LMC truck has them.
Posted via Mobile Device |
When I needed rad hoses for my frankentruck I bent coat hanger wire to the desired shape, measured the diameter and took them to the parts store. Counterguy did NOT even look at the computer, went back and within a couple of minutes came out with a variety. Picked the two that worked (had to trim both for length) and was out the door. Both were premolded Gates hoses. Flex hose is for lazy countermen.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#4 | |
Good luck finding a counterman that is not lazy!
![]() Join Date: Apr 2000
on my 72 4x4 blazer i got a formed one but not sure what is the right part numer,try XL 60990 with a bar code of 37256 00077 think i got it at autozone. hope this helps...
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
All of my trucks use the metal pipe with short pieces of hose at the ends.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Have A Nice Day!
I ran a c10 upper for a few years. Had no problems but later Switched back to metal upper.
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ ![]() ![]() |
hey! i use flex hose.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
I found one at NAPA using the coat hanger trick... I know have an original metal pipe with the rubber ends... either should work fine.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
