Old 06-28-2012, 09:42 PM   #1
1955 mancave
1955 mancave's Avatar
air bags for towing
so on my 64 1 ton what air ride/ air bag set up have you guys used, i plan on using it to tow anything i want without having and issue.
thanks
1955 mancave is offline   Reply With Quote
Old 07-01-2012, 12:00 PM   #2
bama63
bama63's Avatar
Re: air bags for towing
very nice truck not sure on the air bags maybe some of the masters will chime in soon
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-01-2012, 01:08 PM   #3
Pro Performance
Pro Performance's Avatar
I would recommend a 4-link setup with some heavier air bags. Most air springs are rated for around 2500 lbs., but keep in mind it has to hold up the truck also. So, some heavier rated bags and a good 4-link / hardware will be a good way to go. Firestone and Contitech would be some bags I would recommend.
I can get you a heavier universal 4-link setup, heavier bags, and anything else you may need to complete.
Travis
Pro Performance is offline   Reply With Quote
Old 07-02-2012, 03:29 AM   #4
andrewmp6
I would look more in to helper bags they go over the axle to the frame.Your springs will take the load but the bags will help level the load and smooth out the ride like a shock.
andrewmp6 is offline   Reply With Quote
