05-18-2003, 12:23 AM | #1 |
Finally got the 20's on the GMC
Stock suspension. I may bag it later on. I kinda like the stock height for now.
1957 Cameo |
05-18-2003, 12:25 AM | #2 |
I more
1957 Cameo |
05-18-2003, 12:26 AM | #3 |
Rear discs look cool thru the windows in the wheels.
1957 Cameo |
05-18-2003, 12:29 AM | #4 |
What kind of rear disk setup is that?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-18-2003, 12:36 AM | #5 |
Home grown. 1979 k10 front calipers and brackets(bored holes on brackets to fit rear and redrilled 4 mounting holes to fit bolt pattern on axle) , 1984 delta 88 front hoses (they are short) and late model cherokee front rotors (same bolt pattern 5x5, had to bore the center hole to 3.110 and turn 1/4" off diameter to 11.75). Also removed the factory prop valve.
1957 Cameo |
05-18-2003, 12:41 AM | #6 |
Do what? That looks sweet
05-18-2003, 01:18 AM | #7 |
Um, I love 20's and especially them on your truck, but with stock suspension like that, you could easily fit 22's on there :Evil laugh: your truck needs a bath man, come on. lol. And how long did it take you to set up that brake system man? lol, sounds like you're a junkyard king.
Brandon |
05-18-2003, 01:41 AM | #8 |
Sweet, what size tires are those?
05-18-2003, 02:03 AM | #9 |
Thanks for the kind words. The tires are Goodyear gt2's 275/45/20. I have been accused of enjoying trips to the junk yard a little too much. LOL Actually, my brother (who died a couple months ago) showed me how to use parts books to find over the counter parts for the customizing I seem to always be doing. The paint is original and very weak. I have found that washing the truck just removes more of the paint. LOL I worked on the rear discs for about a weekend. I am a machinist by trade, so boring the holes out was a snap.
1957 Cameo |
05-18-2003, 02:41 AM | #10 |
Member since 2000
Lookin Good Those wheels look great!
05-18-2003, 01:11 PM | #11 |
This is not meant to be derogatory, but with the stock suspension, it looks like it's standing on tip-toes.
Looks good.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
05-18-2003, 01:46 PM | #12 |
tip toeing thru the mud !! Maybe I should stick to lifted 4x4's? LOL
1957 Cameo |
05-18-2003, 05:34 PM | #13 |
I removed one coil from front springs with a chop saw. Next, I will install A body rear springs to lower the rear.
1957 Cameo |
05-18-2003, 05:38 PM | #14 |
Like your tires love those rear discs.Wanna do mine
72 cheyenne super |
05-22-2003, 05:48 AM | #15 |
Could someone slam my truck for me in photoshop?
1957 Cameo |
05-22-2003, 07:00 AM | #16 |
drop
Needs a 4/2.5 drop with those rubber band tires. Not proportionate. You'll agree when they photoshop it for you I think anyway, and I'm not even from Ca.
05-22-2003, 08:22 AM | #17 |
Hot Rods For Life
Much better.
05-22-2003, 08:33 AM | #18 |
looking good, but it does look good slammed
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
05-22-2003, 10:24 AM | #19 |
I Love This Stuff!
LOWER!!!! Needs to tuck a bit of rim, then she'd look trick as hell!
My Rides 1967 C10 In Pieces for now 1985 Ford B700 SourPuss Bus - BIG BLUE 2003 Silverado CITY WORKER YELLOW!! |
05-22-2003, 03:55 PM | #20 |
Thanks for your work. I can't tell it has been digitally altered. Do you do that for a living?
1957 Cameo |
05-22-2003, 05:07 PM | #21 |
i thought that all gmc's had leaf spring rear suspensions. that looks like it's got coils. did you put the body on a chevy frame?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
05-22-2003, 05:09 PM | #22 |
Hot Rods For Life
Yep
One more: lower with color edit. Last edited by Zumo; 10-04-2007 at 10:08 PM. |
05-22-2003, 06:31 PM | #23 |
Minor repairs
Never tire of doing what is right II Thess. 3:13 Northeast Missouri 71 LWB original 350 3/speed Soon to be 500 |
05-23-2003, 04:51 AM | #24 |
Fresh paint. You are awsome. Maybe I should paint it for real. Thanks again ZUMO
1957 Cameo |
05-23-2003, 04:53 AM | #25 |
Nightmare, this is original bbc truck with coils, ordered that way for some reason. Makes for easy air bag install I've been told.
1957 Cameo |
