highway manners
ok, here is the problem....i want to make my 72 Jimmy friendlier on the turnpike
350/350 NP205 twin stick 4x4 quadrajet, w/factory cruise, 3.73 I have two choices that i see... Gear Venders Overdrive off ofthe transfer case....3100.00 Winters quick change rear axle...............................2200.00 700R4........................................................................1700.00 Need opinions, advice on which way to go. Im leaning towards the quick change
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-05-2012 at 02:14 PM. |
Re: highway manners
Bigger tires.
Re: highway manners
Na, dont want to snap an axle....dana44, ten bolt
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Re: highway manners
700R4 swap.
Re: highway manners
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Re: highway manners
Nice idea...whats one of them cost?
Re: highway manners
Bowtieoverdrives.com
Posted via Mobile Device |
Re: highway manners
You beat me to it. Went to theFAQs, found a the site, talked to them, 1700.00, and i may be on the way to highway manners
Now i have to read up on whats nvolved, first thing is to shift motor forward 2", shouldnt be a problem, electric water pump and fan Great forum, thanks for the quick replys. Cheaper then gear venders, and quick change
#9 | |
Currently Blazerless
Re: highway manners
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Re: highway manners
If you buy a gear vendors core off ebay cheap, you can send it back to gearvendors and get it rebuilt for about 2000 in total
1954 Chevy Truck 4x4 1964 Pontiac GTO |
#11 | ||
Re: highway manners
54, thanks for the tip, may still go that way. All is still in the planing stage Thanks for the ideas
![]() Join Date: Mar 2012
Re: highway manners
I would say hands down a 700r4 swap would be the easiest and most economical. Or for about the same cost as a gear vendors, go with a NV4500....
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 ![]() |
#13 |
Re: highway manners
I'm still not sure I get it. A 4x4 is never going to get great economy, no matter what.
#14 |
Re: highway manners
I agree with ya! Im just trying to get my engine to spin at a lower RPM? but, around town I dont want a pig with 33 inch tires
#15 |
Re: highway manners
700r4 if your not wheelin with it. but you can pick em up cheaper than 1700 bucks. i had one in my old k5 and my buddy that owned it b4 me went through 5 of em and i went through 3 in a year and a half running stock gears 33s and mild trail riding. good highway mannors though but keep the rpms up it likes to shift in and out of od a lot that will kill it. get a good cooler too they are tempermental in heat.
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT" 2007 cbr 1000rr ![]() |
#16 |
Re: highway manners
go with the 4500 most definatly. very reliable
#17 | ||
Re: highway manners
So, going up hills, would you just take it outta OD? Not off roading is out of the question Let me search out nv 4500
#18 |
Re: highway manners
Yea going uphill the od is too tall to keep momentum goin and I was doing 75 on the interstate driving through Tennessee and Kentucky it as in and out of od so much I said skrew it ill take the higher rpms and took it outta od
#19 |
Re: highway manners
On the other hand my dads 87 has a 700 and never had a problem with it but I just know ill never own one again
#20 |
Re: highway manners
The 700r4 has a good low 1st gear and a od. Heat seems to be the biggest issue with them. Get a good cooler for it and it should be fine. btw stuff is going to brake if you drive it like a teenager. i had one in a k5 on 35s with 410s and it never gave me a problem but i had a transmission cooler from b and m. that truck had 200,000+ on it. o and your going to have to find an adapter for your 205. i think they get a bad rap form guys who put big tires on there truck and don't take the 3.08 gears out of the truck and they blame the transmission.
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
#21 | |
Re: highway manners
Thank youfor the input, BTO didnt mention an adapter....thought it would just bolt up to the NP 205 with the right spline count
#22 |
Re: highway manners
Nope. Only thing that will bolt right up in your truck is another TH350.
#23 | |
Re: highway manners
#24 |
Re: highway manners
You can get an output shaft for the trans that will allow you to bolt up the 700 to the 205. It's from advanced adapters.
BTO should build your trans with the output shaft you ship it to them. I move my engine forward the ~1.75" and kept the trans/tcase crossmember in the stock location. No driveshaft mods needed. What are you running for headers/manifolds? Clearance gets tighter obviously. I am running Corvette straight dump manifolds. Clear the frame rails by 1/4". You may want to swap to 4.10s if you have 33's. Check out a RPM/GearRatio/Trans/Speed calculator to make sure you like the numbers it produces... For instance with my 700r4, 4.56's, and 37" tires I should put out ~2200rpm at 65to70-mph |
#25 |
Re: highway manners
Thanks 71, ill look into that, if BTO is building the trans. Im sure they can put it in at that time. Think there is a core charge? Didnt notice any mention of it
Yeah, im running the same manifolds as you. I did see that they were close to the frame, and i was considering notching the frame out alittle
