![]() Join Date: Mar 2012
Okay, What are high steer arms?? Are these just an upgrade for the stock steer arms? Are they for use in conjunction with a lift? I have never had a kingpin axle so kinda new to all this stuff. Thanks.
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 ![]() |
![]() Join Date: May 2012
Re: High Steer Arms for D60 WTH??
Stock steering on a Dana 60 places the tie rod directly in front of the axle, making it extremely easy to bend it. High steer arms allow you to mount the tie rod above the leaf springs, thus keeping it out of harm's way for better clearance. You should also look into crossover steering while you're at it.
Here is a link to ORD's website that explains it better. http://www.offroaddesign.com/catalog...0crossover.htm |
High steer means to move the tie rod from the stock location at the knuckle to abover the knuckle. You remove the stock knuckle caps and place aftermarket steering arms. Bolt on your tie rod to the new arms up high. Run crossover style steering, and your drag link will shoot over to the passenger side.
Posted via Mobile Device |
So it is mainly for hardcore wheelers then? Is the only advantage the placement of the tie rod?
Essentially, for a daily driver its just shiny expensive parts that dont help much.
Crossover is worth it though. |
#6 | |
So cross over and high steering are 2 different things, I thought they were the same essentially, I am confused now. ![]()
#7 | |
In order to do crossover steering, you'll need a steering box off a 2wd truck. |
#8 | |
Can this be done if I have the Hydro boost setup?
I will have to look into it, is there a kit or do i piece it together?
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 ![]() Last edited by JPalmer81; 07-03-2012 at 11:53 PM. |
There are a few different companies that make a kit to do it. I went with an Offroad Design kit when I did mine on the Blazer, but there are a few others out there. Just remember that you'll need to get a 2wd steering box to make it work. Just Google crossover steering kits and it should bring them up.
Sweet, thanks for all the help beersnob! I am going to look into this cause I have heard nothing but good things from the crossover setup, now that i know what it is, sounds pretty simple.
#13 |
Collector of Projects
Here is the company O bought my kit from.
http://northwestfab.3dcartstores.com/Dana-60_c_33.html PS: Crossover may not clear without a lift. Talk to the mfg of each kit you're interested in. |
#14 |
I have a 4" lift sitting in the garage waiting to go on, and I just found out I may be coming home from deployment a month earlier than I had expected, very excited to get going on my CC!!
#15 |
I thought and i could be wrong here that high steer needs crossover as its the same setup with some obvious extra pieces to move the tie rod out from the front, aside from that its also seems to be common piece on fixing the extremely infamous and highly annoying and dangerous death wobble the dana 60s just love to have
Comapanies that sell them northwest fab Off road design off road unlimited ballistic fab bluetorch fab sky manufacturing Wfo concept And others I can only vouch for off road design but not on the high steer part but they are a great company and have answered me a question for me Posted via Mobile Device
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
