Old 07-04-2012, 04:21 AM   #1
DBear
DBear's Avatar
Degree Shim Help
On my 71 Suburban, I am installing about an 3-4 lift kit, and wanted to know if I need degree shims in the rear, The original owner had shims on it with about a 4 inch kit, but I took it out with the suspension. If I need them, which way are they supposed to go on the axle....fat end to the rear, or fat end to the front???? Thanks in advance!
DBear is offline   Reply With Quote
Old 07-04-2012, 09:52 AM   #2
msgross
msgross's Avatar
Re: Degree Shim Help
It would be fat end toward the rear so the driveshaft angles towards the transfer case, less bind on the u-joints.
Sometimes the rear blocks are already angled though, you want as little angle from the driveshaft ujoint to the rear pumpkin as possible... It doesn't have to be perfect though...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-06-2012, 09:44 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
If you have a single cardan style driveshaft (1 ujoint at both ends) than the angle of the transfer case yoke and the angle of the rear yoke need to be the same at cruising throttle.
If you have a double cardan style drivesaft (2 u joints at one end and a single at the other) than the axle pinion is in line with the driveshaft at cruise throttle.
With everything bolted up, put a angle finder on the yokes and see what ya got.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
