Old 07-18-2012, 05:36 PM   #1
fdwrench
Positraction on not
I have a 72 nova 10 bolt that I will be putting in my 55 second series truck. It looks like it will fit. An inch or two narrower than stock.
Should I go the extra bucks and install positraction or leave it non posi?
I am getting old and the truck will be used just to cruse around the neighborhood.
Thank you
Ed
fdwrench is offline   Reply With Quote
Old 07-18-2012, 06:23 PM   #2
74 shortbed 406
Re: Positraction on not
Imo, every vehicle needs to be locked or have the ability to lock. LSD, air locker, e locker, or straight plain. Open rear sucks.
1978 GMC K25
2002 Dodge Dakota R/T rc swb
In need of some more goodies.
74 shortbed 406 is offline   Reply With Quote
Old 07-18-2012, 07:01 PM   #3
G&R's57GMC
G&R's57GMC's Avatar
Not needed but the Detroit Tru Trac is the best of both worlds, 2 wheel drive when you need it and acts like an open diff going around corners until you put the hammer down.
I've got one in my Tahoe, Avalanche and SSR
G&R's57GMC is offline   Reply With Quote
Old 07-18-2012, 11:54 PM   #4
Kim57
Kim57's Avatar
If it's going to be just a cruiser IMHO you wont miss the posi.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-19-2012, 12:30 PM   #5
OrrieG
OrrieG's Avatar
Unless you plan on driving it off road or during inclement weather (ice, heavy rain) or racing it posi is not needed. Won't hurt anything if you want the bragging rights. Some units can be noisey or clunky. hard core off road guys use air lockers or similar to get absolute locking and control of when it engages.
OrrieG is offline   Reply With Quote
Old 07-19-2012, 01:14 PM   #6
buggy5872
buggy5872's Avatar
I am running an open in my 59. I like it better than when I had a locker. Easier on tires and it tended to want to push the truck while making turns but that might have something to do with the 15.5" wide tires I am running.
buggy5872 is offline   Reply With Quote
Old 07-19-2012, 05:01 PM   #7
OrrieG
OrrieG's Avatar
That is why the 4wd guys use air lockers, its a common problem. Unlock the rear for a second and let the front drive pull you in the direction you want to go, then reconnect when you need traction.
Old 07-19-2012, 05:01 PM   #8
Amorget
If you don't install a posi just make sure to never try to impress anyone with your "one wheel peel"
Amorget is offline   Reply With Quote
Old 07-19-2012, 06:52 PM   #9
oldcouple
oldcouple's Avatar
http://youtu.be/vfgTWY_h-1o
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 07-19-2012, 09:48 PM   #10
LowDown
Do the limited slip/posi .....No one likes a one legger !
LowDown is offline   Reply With Quote
Old 07-20-2012, 10:22 AM   #11
buggy5872
buggy5872's Avatar
I can do a pretty good one wheel peel. with all the smoke most people are shocked its only one wheel. Here's a pic from a burn out contest.
Old 07-20-2012, 10:56 AM   #12
mknittle
mknittle's Avatar
Stay away from a locker for strictly street. they can be a pain on the street. I ran a detroit locker for 30 years in my 684wheel drive.' They are easier to control with a manual transmission by releaseing the clutch. but they still are kind of unpredictable. The True Track is Tourque sensing and are not violent like the automatic lockers.
for moer common used look for Posi Trac or Pontiac safety Trac. Olds had some odd ball rears. so avoid them unless you know what you are looking for.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
