08-12-2012, 09:54 AM | #1 |
C notch a suburban
It looks like it will be hard to c notch a suburban with that crossmember right by we're it goes and the fuel and brake lines on the right side any pics and info on how to do it ?
Posted via Mobile Device |
08-12-2012, 10:24 AM | #2 |
Re: C notch a suburban
It's not impossible, but it does take some time. If you check some of my old threads I think I took some pictures of when I did it to mine.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-13-2012, 08:06 PM | #3 |
i looked and i did not see any thing on c notch info on suburban if any body has any info or pics for me thanks
08-13-2012, 10:16 PM | #4 |
Dave - c-notching a burb is basically the same as a truck. The frames are virtually identical except for the body mounts.
08-14-2012, 10:01 PM | #5 |
BlahBlahBlah
Here is a pic of mine ... well its a panel, but it is exact same chassis as a burb.
09-05-2012, 08:52 PM | #6 |
thanks guys
09-24-2012, 07:27 PM | #7 |
for those of you that have posted in this thread - how low do you go with that C-notch? OP - are you looking to be laid out completely, or just as low as possible without major mods?
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
09-24-2012, 11:43 PM | #8 |
BlahBlahBlah
I dont think you can lay out with a notch, probably get a six inch drop pretty easily though.
09-25-2012, 05:16 PM | #9 |
CG's right. I know that Rob (Hart_Rod) got real low with his C-notch on 15's, so that combined with total tire height will make a difference as to actual bottom end clearance as well. As Hart_Rod stated, take a look at his build as I've read it and its related links who knows how many times. (Thanks Rob!)
The typical ECE/CPP C-notch, as previously mentioned, can definitely be done without cutting the floor, removing the body, etc... and shouldn't be too bad of a job as long as you get the measurements right. However, doing a 2 piece notch like the Porterbuilt will require floor cutting or removing the body since you cannot get to the top reinforcement bolts otherwise. I really like the Porterbuilt C-notch, but since I was going to have to cut the floor anyway with what I wanted to do, I went ahead and ordered the extreme drop rear from Porterbuilt. It will lay frame in the rear even if I decided to go with 24's (but will stick with 20's regardless). More to come... Best of luck with your decision and future mod's!
'72 GMC Suburban 1/2 Ton (Red) '68 C10 Short Fleet (OG 503 Light Green and Patina) '70 C30 Dually (OG City of Charlotte Welding Truck) Past 67-72's Chevy Trucks '68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS) |
09-26-2012, 07:13 AM | #10 |
Thanks guys...now I just need the Suburban
