Old 08-28-2012, 02:37 PM   #1
82ccshorty
82ccshorty's Avatar
2004 duramax rough idle?
I have a 2004 gmc duramax and when its at idle it seems to surge? anybody had this problem or no how to fix it?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 08-28-2012, 08:46 PM   #2
clinebarger
Re: 2004 duramax rough idle?
2 different Duramax engines were offered that year.....
LB7....8th digit 1
LLY....8th digit 2
So whats the 8th digit in the VIN?
clinebarger is offline   Reply With Quote
Old 08-28-2012, 08:47 PM   #3
82ccshorty
82ccshorty's Avatar
It's a lly
Old 08-28-2012, 10:04 PM   #4
clinebarger
If you dont have a scan tool....Have someone check....
1. Fuel Rail Pressure (FRP) sensor & connector.
Verify that actual vs desired fuel pressure match in scan data at low speed and under load and high speed.
Wiggle the FRP sensor connector while the truck is idling, check for RPM change, Replace the FRP sensor and pigtail connector if RPM change is noted.
2. Graph the input pattern (desired) for the fuel pressure regulator.
If the pattern has a saw-tooth appearance, replace the fuel pressure regulator.
I replace the FRP sensor, Pigtail connector &
Fuel Pressure Regulator. If I find ANY of the above.
Old 08-30-2012, 04:57 PM   #5
vern650
vern650's Avatar
generally that's a good sign the fuel pressure regulators bad
'67 c10 lwb-"toothpaste fresh"
'05 3500 dmax/alli ext.cb lwb 4X4
vern650 is offline   Reply With Quote
Old 08-30-2012, 11:13 PM   #6
Pro Performance
Pro Performance's Avatar
My brother in law's 04 (LLY) does this same thing..... surging at idle. I will pass this info along to him as well.
Pro Performance is offline   Reply With Quote
