Old 09-01-2012, 04:51 PM   #1
Frizzle Fry
Frizzle Fry's Avatar
Talking JD2 Tube Bender Hydraulic Conversion
Bought an air over hydraulic ram a while ago at HF with the intention of doing this. Finally took some time off other projects to get it done.
Manual tube bender (JD2 Model 32)
Decided to use existing parts as much as possible without making irreversible changes. This manual lever arm became the host for the ram. Here it is in the manual config (I ended up flipping it over later)
Ring templates/guides for plasma:
Cylinder support:
The cylinder assembly slides on over the existing lever arm and bolts on with 3 1/2" bolts. Holes are evenly spaced so two positions are available.
I plan to add a back-bone to the tube/ram support for increased capacity.
With spacers installed:
Template for the ram attachment bracket:
Installed and working
Frizzle Fry is offline   Reply With Quote
Old 09-04-2012, 12:04 AM   #2
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: JD2 Tube Bender Hydraulic Conversion
That is slick!
screamin_c10 is offline   Reply With Quote
Old 09-06-2012, 12:43 AM   #3
Frizzle Fry
Works great. Guess you and I are the only ones who understand the what it does
Old 09-06-2012, 01:47 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
That's VERY cool! Better than what most exhaust shops have....that's for sure
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-06-2012, 01:48 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
Building a roll cage for the minx?
Old 09-06-2012, 08:18 PM   #6
Frizzle Fry
No cage for the Minx just yet but I did use it (manually) for the A-arms, engine mounts, and front frame cross-brace. My wife's FJ40 will see the first benefit from this; cage, bumper, sliders, maybe tube fenders, etc.
Old 09-06-2012, 08:48 PM   #7
Dunenutt
Newbee
Dunenutt's Avatar
I keep threatening to do that to mine...
I keep forgetting how much it hurts, until I get done with another cage.
I do have a 5' handle though
Dunenutt is offline   Reply With Quote
Old 09-08-2012, 10:52 PM   #8
screamin_c10
Wish I had one... would save a fortune in mandrel bends and pre-bent stuff for the Chevelle and future projects...
Old 09-09-2012, 01:37 PM   #9
Frizzle Fry
Wish it could do exhaust!
Old 10-13-2013, 07:04 PM   #10
Bomp
Bomp's Avatar
My Jd32 arrived last Friday, ordered the same ram from HF and its here. Have two sticks of 1.5" .120 DOM ready for bending.
Your write up on the bender is going to have a major impact on my build.
Thanks for taking the time on the info.
Bomp is offline   Reply With Quote
Old 10-23-2013, 10:22 AM   #11
Frizzle Fry
Hey Bomp, just saw this. Glad to help bud
Old 10-23-2013, 11:09 AM   #12
bnoon
I've dreamed of doing something like this. Glad to see someone has the time to make the dream come true and work out the bugs before I get to it. :-)
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 10-23-2013, 09:00 PM   #13
Frizzle Fry
One of the best things about this conversion (besides the obvious advantage of being hydraulic) is that it is now mobile and does not have to be bolted down to use. The stand I have it on now has 6 casters
Old 12-08-2013, 10:05 PM   #14
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Very well done. Maybe I can get this setup someday. Thanks for posting.
Alan's Classic is offline   Reply With Quote
Old 12-09-2013, 03:13 PM   #15
Frizzle Fry
Thanks Alan. I saw that Bomp has his converted and twisting tubes up! I'm sure you guys will improve on it
Old 12-21-2013, 04:13 PM   #16
maxxxy
maxxxy's Avatar
Just got the manual version of this at work, it sure is a lot of fun to play with. We are running it in the horizontal orientation. Added a hitch receiver style mount that slides into a slot in the top of our welding table.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 01-28-2015, 03:34 AM   #17
screamin_c10
Hey Mike... Guess what I'm getting with this next bonus... Gonna do the hydro mod as well (shamelessly ripping off your ideas).
I just got done doing an HF bead roller with winch motor and foot control. Works like a charm.
Old 01-28-2015, 04:56 PM   #18
rambler
MOVE OVER
rambler's Avatar
lots of talent here.. wish I could do something like this..
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 01-29-2015, 02:49 AM   #19
swamp rat
swamp rat's Avatar
Sooooo........ did anybody post a how too on this one somewhere?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-30-2015, 12:15 AM   #20
Frizzle Fry
Do it!
I need to mod my bead roller. Where's the build?
Old 02-04-2015, 03:47 AM   #21
screamin_c10
I'll get it posted up ASAP...
Old 02-04-2015, 04:41 AM   #22
screamin_c10
http://67-72chevytrucks.com/vboard/s...d.php?t=658922
Old 02-05-2015, 04:20 AM   #23
swamp rat
swamp rat's Avatar
Thanks for the link!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-29-2015, 03:14 PM   #24
watahyahknow
watahyahknow's Avatar
you might be able if you fill the tube with ice
they make trumpets and trombones by filling the pipes with water and freese them before bending , after bendeing they just les the ice taw out and pour it out of the pipe
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-30-2015, 04:55 PM   #25
Frizzle Fry
You're right, might work! I just checked and the biggest die set they make for my bender is 2.5" dia. Big enough for lot's of stuff.
I bent thin-walled aluminum in this bender by annealing it and packing it with sand.
Problem with ice is finding a big enough freezer to put the pipe in..
