Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-06-2012, 10:44 PM   #1
KINCAID
np 208 transfer case leak ?
i have a 1970 chevy 4x4 short bed. i have a 700 r4 bolted to a sb 350 and a np 208 t/c. with a 4 inch lift. just had t/c rebuilt since it was leaking. i still have the same leak . it leaks where the tailshaft housing meets the case. is this a weak spot ? to much angle or pressure from rear drive shaft ? your help is greatly appreciated
KINCAID is offline   Reply With Quote
Old 09-07-2012, 01:39 AM   #2
rcbildr
rcbildr's Avatar
Re: np 208 transfer case leak ?
Does it look like it is leaking from a bolt hole, or where the two cases meet up? IIRC the 208 has a lot of bolt holes that go in to the case and if you don't put rtv/sillicone on the bolts, you will have leaks.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 09-07-2012, 10:42 AM   #3
KINCAID
it is where the two meet up . the bolt holes does not leak . it leaked in the same area before and gets worse as u drive it to the point its bad. so i had it totally rebuilt . with in 15 miles of putting it back in. i have the same leak again its near the bottom. its not bad yet but leaking
Old 09-10-2012, 10:22 PM   #4
rcbildr
rcbildr's Avatar
I wonder if it might be cracked there. Can you post a pic of the leak? Probably asking the obvious, but is the surrounding area clean enough to verify the leak is there and not a drip/run from someplace else? I figure it is because of the fresh rebuild, but you know how sometimes the most obvious is the hardest to see when you are frustrated. The 85 burb my girlfriend drives has a 4" lift and it doesn't leak from there.
My Projects:
1978 Camaro Z28
