Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-01-2012, 08:12 PM   #1
bk04z66
Granny smith, 71 2wd build
Well I thought maybe if I put a build thread up I might get my ass in gear.
Its a medium olive stripper model 71. Here is a pic the day I brought her home in june of this year.
bk04z66 is offline   Reply With Quote
Old 10-01-2012, 08:19 PM   #2
bk04z66
Re: Granny smith, 71 2wd build
Here is the donor 72 I picked up a month later, I was going to just swap the tubs, but the 71 is not "as bad" as I first thought. Im just going to cut up the 72 and use the exterior panels.
Old 10-01-2012, 08:28 PM   #3
bk04z66
Over the past month I have fixed the wiring from the PO's. Its running and charging good now, but I think the cam might have a few wiped lobes. One of the PO's swaped the six/3OT combo for a 8/turbo 350. One thing I noticed after looking at a few C10's is during the swap they put the engine in the rearmost position, which I like, there is still clearance behind the hei. Last week I picked up a new truck floor from a local supplier. Last night I started cutting out the "good" side of the floor.
Old 10-01-2012, 08:45 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I like your 2wd very much.
Keith
Convert to disc brakes.
Old 10-02-2012, 09:00 AM   #5
bk04z66
Plans are to get rid of the holes in the floor, fix up the interior and drive it.
Over the winter its getting bagged.
Old 10-09-2012, 10:23 AM   #6
jaros44sr
jaros44sr's Avatar
So, whats up with the build....curious to see how things are coming along. Any deconstruction pics.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-20-2012, 10:03 PM   #7
bk04z66
I actually got some things done the past few weekends.
Got some of the floor cut out. Got the auto column put in out of the donor, put a new masterpower unit in.
Old 10-20-2012, 10:05 PM   #8
bk04z66
If this was a 100point restoration, would I have to recreate the factory paint runs? ha
Old 12-23-2012, 08:38 PM   #9
PHAT TONY
PHAT TONY's Avatar
Well.....Get your ass in gear man!! I wanna see you save this rare beast!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-23-2012, 09:11 PM   #10
turp mcspray
turp mcspray's Avatar
Smile Re: Granny smith, 71 2wd build
I sure wouldn't! I always hate when someone says, that they want it perfect, like it was when it was new. My response is usually something along the lines of, "you must not be very fussy are you?!" LOL!!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 12-23-2012, 09:15 PM   #11
turp mcspray
Hey Tony, is it getting "chilly" up there in the great white north?!
Turp Mcspray
Old 12-24-2012, 12:01 PM   #12
Bentblazer
Bentblazer's Avatar
Looks kinda like one I've seen from the Fulton area
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 12-25-2012, 08:07 PM   #13
bk04z66
Have not gotten very far, but it is coming along. I will not have it bagged, but I will be driving it by spring.
Old 12-27-2012, 12:15 AM   #14
PHAT TONY
PHAT TONY's Avatar
....wow.
1972 K10 4X4-Sold
Old 12-27-2012, 01:11 AM   #15
jaros44sr
jaros44sr's Avatar
Nice! Make sure the outside leading edges of the toe area, right where the pan meets up to the factory seam, is straight with the rest of the pan. When i installed the prototype on their truck i had to fool with that area. It was an area about 6-8" long....maybe they fixed it once it went into production, told them to
You wont believe how much time that piece will save you, compared to the old patch panels
SAFETY FIRST
AS usual, off topic
Jim
Old 12-27-2012, 09:51 PM   #16
bk04z66
I am kind of concerned with fitment of the panel. I have left what is not rusted off of the original alignment features. Any way you can circle an image of the floor where you are reffering to? I have an idea its around the toe patch that I have put in. I should have the panel in by new years. Just measured the bench seat mounts and see they are not in the right spot for the buckets (in towards the center about 1.5"). so now I have to relocate them.
Old 12-27-2012, 10:09 PM   #17
jaros44sr
jaros44sr's Avatar
Sure, up in post #13, your pic has three little white dots. Upper left side of pic. Dont know how to circle... Lmk, if you dont understand the location im referring too
SAFETY FIRST
AS usual, off topic
Jim
Old 12-27-2012, 11:40 PM   #18
bk04z66
Understand, the panel I have does not look to bad in that area, but wont know until I get it in there, kinda bummed the seat mounting holes where in the wrong spot, killed my momentum yesterday.
Old 12-27-2012, 11:47 PM   #19
jaros44sr
jaros44sr's Avatar
As long as its straight in that area, youre good to go....can you find the square nuts and weld them in to fix the seat location problem?
Yeah but, look at it this way....you have a rust free floor going back in. Alot of people would like tohave that floorboard
SAFETY FIRST
AS usual, off topic
Jim
Old 12-28-2012, 12:02 AM   #20
bk04z66
Yep, I think complete floor was the way to go, pretty sure the factory was 18 ga. the triplus parts are 1.2mm. The triplus rocker boxes I bought are super thick. Im just going to drill the spot welds on the seat mount plates and move them over to the blazer locations. I would have thought for sure gm would have made bench and buckets use the same outer holes, but I guess not.
Old 12-28-2012, 12:12 AM   #21
jaros44sr
jaros44sr's Avatar
Good idea on moving the plates...tri pro has always treated me good on parts...
SAFETY FIRST
AS usual, off topic
Jim
Old 12-31-2012, 03:14 PM   #22
Splash4195
WOW going to be a good build!
Splash4195 is offline   Reply With Quote
Old 01-16-2013, 10:06 PM   #23
bk04z66
Over new years I got the floor all prepped and put in. What a PITA, took forever to get the seat bracing cut out and positioned in the new pan. I cut/formed the rear of the pan almost exactly like the old floor was.
Old 01-16-2013, 10:12 PM   #24
bk04z66
Managing the whole floor in one piece by myself was a chore, but its done.
Got a little discouraged, my dad sent a CL link to a nice looking 72 white 2wd in SC. His asking price was less than what I have wrapped up in this one. I called the day after the ad was posted and it was gone.
Old 01-17-2013, 01:17 AM   #25
jaros44sr
jaros44sr's Avatar
How did you make the back bend on the floorboard, and what tools did you use
Looks great...enjoying your progress, thanks for sharing
SAFETY FIRST
AS usual, off topic
Jim
