Old 10-23-2012, 10:53 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Air Management Setup Pictures
Looking for some ideas and wanted to see how you set up your air management, that is the layout of your tanks, compressors, valves, etc.
Let's see what your great minds have designed.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-23-2012, 10:54 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Air Management Setup Pictures
Here's an example which was created by tcb-1:
-Nate
Old 10-25-2012, 05:18 PM   #3
Gus350
68 C 10
Gus350's Avatar
Don't be shy boys lets see them pics.......
TTT
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 10-27-2012, 10:35 PM   #4
ChopperCity256
ChopperCity256's Avatar
i'm interested also! I have accuair and was wonder how other people did their setups..
ChopperCity256 is offline   Reply With Quote
Old 10-28-2012, 01:11 AM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Who was the vendor that came up with something like a drop down battery box? They aren't producing it yet, but it sure was slick.
Zoomin is offline   Reply With Quote
Old 10-28-2012, 09:04 AM   #6
502ms
502ms's Avatar
I will post mine when I get to my computer
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 11-01-2012, 08:17 PM   #7
dznucks
dznucks's Avatar
I remember seeing this. I dont recall it being a vendors though. It was pretty slick though.
ChopperCity, is your accuair installed? I have the accuair system on my DD.
dznucks is offline   Reply With Quote
Old 11-01-2012, 09:01 PM   #8
Rochlow
On my 97
Rochlow is offline   Reply With Quote
Old 11-01-2012, 09:21 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
We are making them. Some pics are in the "Old Aux" thread.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-01-2012, 09:23 PM   #10
Rochlow
What's the price?
Old 11-01-2012, 10:13 PM   #11
Rusbuilt
Rusbuilt's Avatar
This one is Nacho's that Delmo built. I saved the pic because I really like the way it was done.
Rusbuilt is offline   Reply With Quote
Old 11-02-2012, 12:17 AM   #12
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Thanks, nice to know I didn't dream it. Link
PM me with the info if you would, please.
Old 11-02-2012, 03:17 AM   #13
fat56
fat56's Avatar
Accuair all hidden under the cab and i have a drop down battery box on the other side.
Blake. Sydney Aus
56 Chev 3100
build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363
LOW n LOUD
fat56 is offline   Reply With Quote
Old 11-02-2012, 07:07 AM   #14
dznucks
dznucks's Avatar
I mounted all my Accuair components in a box. Compressor is in the same location on passenger side. Two three gallon tanks mounted on the frame rails. The supply side of the system is all 1/2" hard lines supplying both inputs to the valve block, the feed side is 3/8" plastic lines.
Old 11-02-2012, 11:07 AM   #15
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by Rochlow View Post
What's the price?
They run $79 a piece... or the pair for $150.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-02-2012, 11:42 AM   #16
SBC
SBC's Avatar
nice. do you know if there's any way to attach a 3gallon Airpod system to one of those brackets.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 11-02-2012, 11:51 AM   #17
PBFAB.COM
PBFAB.COM's Avatar
I don't know for sure. They are designed to be used with a 3 gallon tank... and I have mocked it up with the aluminum ridetech tanks, but not sure if the air pod would fit as a unit.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-02-2012, 11:58 AM   #18
jimmydean
jimmydean's Avatar
Mine will be similar to this only mounted to the frame rather than the bridge. I am not using the Accuair mount because my tank is too big. But it will be similar.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-08-2012, 09:54 PM   #19
Rochlow
Less than $10 to mount all this
Old 11-11-2012, 03:19 PM   #20
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Ran across this setup while cruising the net today...
Link
Old 11-11-2012, 04:14 PM   #21
joel.e
joel.e's Avatar
If you are going to run a rear fuel tank it seems real estate gets limited to hide a tank if you are going to keep a stock bed floor. Has anyone put the stuff behind the seat?? I know the tank will fit but will the compressor(s) drive you crazy? I've never had a full air suspension system so I don't have a feel for how much the compressors would run? I'm guessing the intake noise is the majority so you could duct the pickup out the floor or something. What do you think?
joel.e is offline   Reply With Quote
Old 11-11-2012, 04:41 PM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I personally wouldn't recommend placing the compressor in the cab... I think you will regret it in the first few minutes.
-Nate
Old 11-11-2012, 05:35 PM   #23
big_al_71
big_al_71's Avatar
mine is on the passenger side in front of the tire...Raul built an aluminum plate and bolted it all in...it's been there for a year..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-12-2012, 06:38 PM   #24
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Link
Thanks dude.... Here are a couple more pics of our brackets. Can be mounted a few different ways and we even have Accuair valve mounts for these.
AVS_JASON is offline   Reply With Quote
Old 11-12-2012, 06:42 PM   #25
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Here is one more with a pic of the Accuair manifold mounted to the top.
