Old 11-28-2012, 11:24 PM   #1
69sinker
69sinker's Avatar
02 camaro harness questions
I have a complete 02 camaro donor car and I'm wanting to use engine,trans and install dash into 69 lwb. Any ideas on working harness?
69sinker is offline   Reply With Quote
Old 12-01-2012, 04:23 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 02 camaro harness questions
check out www.lt1swap.com He breaks down how to do it pretty good.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 12-02-2012, 09:24 PM   #3
69sinker
69sinker's Avatar
Spent several hours on harness this weekend but still unclear on a lot of wiring ( termination points, connectors, etc ) lt1 does have a lot of info but I'm beginning to think I should just spend the money on a new harness.
Old 12-03-2012, 10:24 PM   #4
69sinker
69sinker's Avatar
Any suggestions on swap mounts? And is it possible to keep alt. and a/c in stock location( low)and has anyone used stock camaro manifolds without extensive frame mods.
Old 12-04-2012, 05:08 PM   #5
faribran
easy enuff to make your own mounts..if you have some tools and a welder.. lots of patterns floating around...
faribran is offline   Reply With Quote
Old 12-04-2012, 10:49 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
check out TransDapt
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-04-2012, 10:59 PM   #7
69sinker
69sinker's Avatar
Thanks for info. Ordering CPP perches and mounts today . Worked on harness ,ready to get fuse block and relays hooked up. I'm hoping to use stock 02 camaro manifolds for now.(anyone had any luck with these?)
Old 12-05-2012, 03:58 AM   #8
ls1nova71
ls1nova71's Avatar
F body manifolds fit pretty good. You do have to clearance the frame on the passenger side to clear the bump where the air tubes go and also the flange but its not much at all. There's pics in my build thread in my sig.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-05-2012, 08:02 PM   #9
69sinker
69sinker's Avatar
Thanks for info,enjoyed your build. Can't wait to get this project rolling /running! This truck has been a 6 year project for me and 2 of my sons, they lost interest so I'm taking it on mostly myself.Im amazed how much ls swap info is on this site, it takes out alot of guess work and some great ideas, thanks again for everyone's input.
