Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-15-2012, 12:43 AM   #1
KrazyRay
KrazyRay's Avatar
Factory Rear Sway Bar
EDIT: AS OF MAY 15TH 3RD ONE AVAILABLE...FREE SHIPPING!
This is the identical one pulled from a 1 ton as the ones that member 1774btcrew sold recently. This is the first one I have come across so I think they are pretty rare. I was able to save the u bolt saddles, u bolt spacers, and 2 of the extra long ubolts all of which are included. You will need 2 u bolts and probably new rubber bushings. $150 plus shipping.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 12-15-2012, 01:42 AM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: Factory Rear Sway Bar
Ray think this would work with a flipped axle?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 12-15-2012, 11:31 AM   #3
KrazyRay
KrazyRay's Avatar
It would have to go on top and there would not be enough clearance to the frame.
Old 12-26-2012, 06:15 PM   #4
KrazyRay
KrazyRay's Avatar
Ttt
Old 01-21-2013, 11:34 PM   #5
KrazyRay
KrazyRay's Avatar
Sale pending to member undr8ed.
Thanks,
Ray
Old 01-22-2013, 01:42 PM   #6
1774btcrew
1774btcrew's Avatar
Ray,
Glad you got it sold.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 05-05-2013, 10:12 AM   #7
KrazyRay
KrazyRay's Avatar
ttt still available undr8ed did not follow through.
Old 05-05-2013, 01:14 PM   #8
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I have a standard 73 3/4 longbed C/20.
Will this correctly bolt into my truck?
I just need to know that it is correct for my truck before I can commit to taking it.
Let me know...THX
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 05-06-2013, 10:03 AM   #9
KrazyRay
KrazyRay's Avatar
Yes. It will bolt to your truck. You might have to drill a hole on each side of the frame for the studs to mount on to.
Thanks,
Ray
Old 05-06-2013, 10:32 AM   #10
RPOZ11
RPOZ11's Avatar
Cool Re: Factory Rear Sway Bar
Ok then.
Nothing missing, correct?
PVT mssg me the details on paying you.
Thx
HO72 build :
2017 SS
Old 05-13-2013, 08:29 PM   #11
KrazyRay
KrazyRay's Avatar
Here's a 2nd one...$150 with free shipping!
You will need u bolts, washers, nuts and probably new rubber bushings all should be readily available at the store.
Old 05-13-2013, 08:43 PM   #12
kevinr1970
It seemed that 1774btcrew said before that these can be used on a lowered truck. I asked for confirmation in his thread but it was never responded to?
Is it the "flipped" part that makes this unusable on lowered trucks, or is it all lowered trucks?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 05-13-2013, 09:40 PM   #13
RPOZ11
RPOZ11's Avatar
Hhmmm i might be interested in this one.
HO72 build :
2017 SS
Old 05-14-2013, 12:12 AM   #14
KrazyRay
KrazyRay's Avatar
I think it is the "flipped axle" that would be the problem because the sway bar goes on the opposite side of the axle from the leafs. So if the leafs were on the bottom of the axle, then the sway would be on top and end up hitting the frame. If you use lowering springs or shackles, the sway bar should work fine. You might have to cut the frame mounting sleeves down to square it up with the lowered truck.
Old 05-15-2013, 07:02 PM   #15
KrazyRay
KrazyRay's Avatar
2nd bar sold pending payment. Thanks!
I have another bar available.
Old 11-13-2013, 02:28 PM   #16
KrazyRay
KrazyRay's Avatar
ttt for midunes
Old 11-13-2013, 06:33 PM   #17
midunes
midunes's Avatar
Paypal sent look forward to installing this
Thx
midunes is offline   Reply With Quote
