12-18-2012, 12:29 PM | #1 |
C/10 junkie
Air bag installation
Can someone point me to a thread that shows how to install a basic bag setup for say a 68 swb coil spring truck? Looking for a thread that shows how to install a PorterBuilt stage 1 kit front and rear. Thanks guys in advance.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-18-2012, 12:48 PM | #2 |
67-72 parts collector,…
Re: Air bag installation
Not a Porterbuilt thread,... but a good "basic" airbag thread from our FAQ area.
http://67-72chevytrucks.com/vboard/s...d.php?t=129463
12-18-2012, 12:49 PM | #3 |
C/10 junkie
Thank you Keith, I'm not quite ready for a bag conversion but I want to start getting all the info I can to make the best decision. Also is there any threads for cupping the lower control arms? I was kinda thinking it may be better to just buy a set of aftermarket lower control arms with bag mounts built in.
12-18-2012, 12:51 PM | #4 |
Bag install is pretty straight forward.
Your choice of air management is where you can spend some cash!
12-18-2012, 12:54 PM | #5 |
C/10 junkie
Yeah I see there is a ton of choices in that regard
12-18-2012, 01:14 PM | #6 |
C/10 junkie
Hey Keith in the link you posted does the front lower cups just sit in the spring pocket or do you weld them in?
12-18-2012, 01:18 PM | #7 |
They just set there.
Most cut them down to 1-5/8" to 1-3/4" tall,... to get the maximum drop.
12-18-2012, 01:22 PM | #8 |
C/10 junkie
Ok, I get it. Thanks
12-18-2012, 01:33 PM | #9 |
C/10 junkie
So in the Porterbuilt stage 1 rear kit does the upper bag cup not allow the rear to sit as low as the way the guy in the link did his rear bag install?
12-18-2012, 01:37 PM | #10 |
C/10 junkie
Another question is I have a CPP notch installed already, if I wanted to go with a Porterbuilt notch how far will the holes be off?
12-18-2012, 01:45 PM | #11 | |
This allows for easier mounting and air line install. I would just use your CPP notch and install the bag directly to the frame, without the hat. But that will require you to drill 2 bag mounting holes in the frame,... and 1 giant hole for the air bag fitting to pass thru. The upper hat makes it easier,... and that amount of added height can be offset by using a lowering block. The rearend center section will hit the bed floor, BEFORE the axle tube is all the way in the notch, anyway.
12-18-2012, 02:11 PM | #12 |
C/10 junkie
Gotcha, thanks for all your knowledge Keith, I really appreciate it.
12-18-2012, 10:03 PM | #13 |
I recently installed PB stage 1 in front and stage 2 in rear. Once you look at the pieces it's pretty straight forward. Just a lot of drilling. Once I fix my brake problem I could post some pics if you like.
1967 C-10 Project 2008 Suburban 2017 GMC Sierra |
12-18-2012, 10:20 PM | #14 | |
C/10 junkie
12-18-2012, 10:46 PM | #15 |
Here is the Stage 1 kit without a c-notch. Since you have a c-notch, i would just remove the upper cup and that should put you where you need to be or at least very close.
12-19-2012, 10:51 AM | #16 |
C/10 junkie
So are you saying that's about as far down as the axle would go because of th bag cup? Or because I have a notch it would go farther? To me as long as the pumpkin hits the bottom of the bed floor aired out with the bag cup that would be fine ad plus it's much easier I install.
12-19-2012, 11:38 AM | #17 |
Wait .. what's all this? Bags?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
12-19-2012, 11:41 AM | #18 |
In that picture, it is sitting on the internal bumpstop in the bag. If you remove the cup, it will move up that much farther until the axle hits the bed floor, which might be about another 1" appx.
If you are looking at the Porterbuit Stage 1, you can always put the cup on the top to see where it is at, and then remove if it is not needed. |
12-19-2012, 11:44 AM | #19 |
C/10 junkie
Yep, I am in the stage of gathering info to see how I want to go about it
12-19-2012, 11:46 AM | #20 |
Is the white truck in the Avatar what you are wanting to put bags on?
That things sits low for a static drop! |
12-19-2012, 11:47 AM | #21 | |
C/10 junkie
12-19-2012, 11:49 AM | #22 | |
C/10 junkie
12-19-2012, 11:56 AM | #23 |
C/10 junkie
And what really got me going again was I sold my 5" drop springs to put in some 6" drop springs. So while I am waiting for my 6" springs to arrive its been sitting at my shop like this and I REALLY LIKE IT!!
12-19-2012, 12:23 PM | #24 |
I agree, that would be enough motivation for me right there! lol
12-20-2012, 11:01 PM | #25 |
I highly recommend Porterbuilt. I have both the front and rear kit, and also the c-notch. There are several pics in my build thread, here are a few
=MATTHEW 69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
