12-27-2012, 05:36 PM | #1 |
Wheel back spacing
I have a 1953 Chevy and am using a Mustang II up front Ford 9" that measures 60 inches wide in the rear. I'll be running 16x7s up front and 17x8s out back. What backspacing do I need on both?
12-27-2012, 06:38 PM | #2 | |
Re: Wheel back spacing
Make sure to measure both sides front/rear. I have a MII front w/air-ride(bags & shocks) and run 17"x7" with 3 3/4" backspace front and a 10 bolt rear with 18"x8" w/ 4" b.s. Works for me but the 10 bolt may be a little wider. If you can get it to a good tire/wheel shop they could measure and tell you for sure. Also, some custom wheel sites show how to measure for backspace. What kind of wheels are you running?? |
12-27-2012, 06:53 PM | #3 |
Hi this picture kind of exsplanes how it all works
The numbers are all wrong but the principal is there Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
12-27-2012, 06:59 PM | #4 |
where did you get this converter? thanks
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
12-27-2012, 07:06 PM | #5 |
Take a look here
http://www.rimsntires.com/specs.jsp Hope this helps Posted via Mobile Device Posted via Mobile Device |
12-27-2012, 08:29 PM | #6 |
If the tires have to clear the factory bed sides 3 inch max back spacing. That should give you almost an inch of clearance between the tires and the bed.
12-28-2012, 01:23 AM | #7 |
I'm going to tub the bed. Should have said that. I'd like to run 265/65/17 rears and 225/60/16 fronts
