LM7 5.3L to F-body oil pan
I have a 2001 LM7 5.3L engine i am putting in a 1979 chassis that is lowered on airbags. when the truck is lowered, the oil pan sits right on the ground.
kind of thought it would. i was thinking of using a F-body oil pan to gain plenty of clearance. i found these numbers, anybody know if they are correct? or anybody made this change? 12558762 oil pan 12558251 pickup tube 12558253 windage tray any advice would would be great.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
![]() Join Date: Jul 2006
Re: LM7 5.3L to F-body oil pan
I'm not sure about the part numbers, but the F-body pan will solve your problem, I think it's only about 5.5" deep. I have one on my airbagged '50, Mustang II front with 5.3L and it's a good inch or two higher than the crossmember.
My only tips are be careful of used pans, look very closely for cracks. Also, there is a special alignment procedure for these pans. I think CTS-V and a couple of other styles will work too. Leevon
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
I have an 05 5.3 and swapped to a f body pan.....pace performance has an entire setup( dipstick, tube, windage tray, pan, gasket, bolts, pickup tube) it ran me 320 shipped to me. not sure of your budget but I thought it was a fair deal
#4 | |
hmm pace performance? will have to do web search, thanks for the info.
Basically, you just want to make sure the back edge of the pan is aligned with the back of the block due to the fact that the transmission bolts to it. If it's overhanging the block, or in too far, bolting the transmission up tight will cause alignment issues. The shop manual says to put a straight edge on the back side, but it's not practicle if the engine is in the vehicle. Also, put a dab of silicone on the 4 corners of the pan gasket where the front and rear covers meet the block to prevent leaks, there is a little crosshatch area on the gasket in those areas if I remember correctly.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: LM7 5.3L to F-body oil pan, CTS-V pan?
after measuring again
maybe a CTS-V pan would be best CTS-V oil pan: Part#12605814 Oil pan defector: Part# 12611129 Oil pump pickup: Part# 12621299 Oil dipstick tube: Part# 12584737 Oil dipstick: Part# 12584738 anybody used the cadillac pan?
I used an f-body pan in my swap and it has great clearance. The stock truck pan hung too low for comfort for me and I'm only static dropped 4.5". I got my stuff used from www.ls1tech.com classifieds.
#8 | |
I have in my 69 c10 sits abou 1/2 inch above x member but I think it depends on which motor mounts your using here some photos
![]() ![]() Posted via Mobile Device |
Definitley! If it's not seated all the way you'll ruin the pump! Had a buddy do that on a fresh rebuild, he got the fun of pulling it again.
which pan is that? hard to tell upsidedown
now it looks like the caddy pan after some serious web surfing.
but i am going to wait until motor mounts come back and measure again before i order pan. dont want to send two back.
#13 |
F-body pan vs. truck pan
#14 |
This is in my 68, which is similar chassis design as a 79.
#15 | ||
![]() Join Date: Apr 2005
http://www.gmtruckhq.com/lsx-tech/ls...them-2720.html Quote:
![]() Edit: Here's another thread: http://67-72chevytrucks.com/vboard/s...d.php?t=272174
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-02-2013 at 12:10 PM. |
#16 | |
don't worry about the hi-jack, it might have an answer i wanted to know ![]()
#17 |
see the pictures i modified, i am thinking the caddy pan is best fit. second picture said holden, but looks real similar to caddy pan.
#18 |
I posted pictures of the caddy pan installed in my burb build thread.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#19 |
gm musclecar pan in my 86....kinda hard to tell, but it's about 3/4" above the bottom of the crossmember.....If I was doin it over I'd get the f-body pan or the Holley pan....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#20 |
Fabricate till you "puke"
I am looking @ the Gm musclecar pan for my 69, but a ? What would sway you to the other 2 pans that you mentioned...(oil capacity, fit, ect.)? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#21 |
the f-body and holley pan are shorter still....more ground clearance..
#22 |
#23 |
I also have a 5.3l in a TF chevy truck, I did use an Ls1 pan but would probably go with the Caddy pan if I was to do it again, the camaro pan is shallower but the sump is longer front to back if you are running a camaro or similar clip the fit is very tight from rear of crossmember to front of sump with the engine set very close to the firewall.
Learn to deal with reality, or reality will deal with you. |
#24 |
does anybody know if these are current GM numbers?
CTS-V oil pan: Part#12605814 Oil pan defector: Part# 12611129 Oil pump pickup: Part# 12621299 Oil dipstick tube: Part# 12584737 Oil dipstick: Part# 12584738 also anywhere to get these besides GM dealers or GMpartsdirect?
#25 |
Check the classifieds at ls1tech.com. That's where I got most of my stuff.
