Bbw sec,60-62 shroud, 60-63 sail panels,dash,grilles
BBW section $260 plus ride need some small hole repair Sold
![]() ![]() ![]() ![]() 60-62 Shroud $150 plus ride ![]() ![]() 60-63 dash $120 ![]() sail panels $80 plus ride Sold ![]() ![]() ![]() 62 grille nice shape $125 plus ride blue grille sold ![]() 60 grille $120 plus ride ![]() 60-62 auto trans cross member $80 plus ride Sold ![]() Hood cowls $30 ea plus ride ![]() 73-87 step side short bed used wood maybe someone put a newer bed $125 plus ride ![]() ![]() Last edited by perro13; 01-28-2013 at 07:52 PM. |
![]() Join Date: Nov 2010
Re: Bbw sec,60-62 shroud, 60-63 sail panels,dash,grilles
PM Sent on shroud.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Perro,
I know dtkarst has dibs on the shroud, but could you get me a couple measurements? I need the height of the mounting flange, and the bolt hole spacing. See this thread: http://67-72chevytrucks.com/vboard/s...=364381&page=2 Thanks, Robert Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-03-2013 at 06:03 AM. |
the height is 8 1/2,to sets of mounting holes from center to center 5 1/2, 7 1/2 hpoes that helps
![]() ![]() Last edited by perro13; 01-03-2013 at 01:11 PM. |
![]() Join Date: Oct 2006
I will buy the auto crossmember and sail panels mark them sold
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 01-03-2013 at 01:19 PM. |
Cross member & sail panels sold Slepysal
Orale.Thanks for the "home Boy" hook up. Nice meeting you hope to do busines with you again. Real cool guy .Thanks again
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Looks like you made it back home with the parts. Im just glad they are out of my garage...lol ill let you know when I get more. see you at Pomona.
PM sent on 62 grille
#13 |
![]() Join Date: Jun 2007
Perro, on all factory automatic trans equipped 60-62 trucks there are two crossmembers; the one you are showing which holds up the bellhousing, and a second smaller wedge shaped one farther back than the torsion bar support that bolts in right in front of the X frame's driveshaft tunnel. I wonder if you can look and identify whether or not your frame has this piece, and if so if you would sell it?
#14 |
#15 |
Got the Grille...FANTASTIC! Just opened it up and it looks even better than the pictures you sent. Thanks again!!
#16 |
