Old 01-11-2013, 07:41 PM   #1
Cherub
Cherub's Avatar
Cherubs 4x4 suburban
Well i sold the 1978 burb in order to pick up a something 4x4. I settled on this 1983 3/4t GMC suburban. I didnt really want to create a build thread but still wanted to use this to bounce question off yall. Keeping it all in one place.
I didnt bother getting good pictures of it when i bought it but here are some cell phone pics.
Here is the tires i plan on using 36x12.5x16.5 military tires.
Lifted it with a 6" rough country springs in front and blocks & add a leaf...the blocks that come with the kit were cheap but i was lucky enough to have a friend some used ones.
It didnt have carpet when i got it (later i found out why) so i added some for the passenger area.
a few of the problems.
It pulls hard to the right when i brake but tracks well when driving. im going to get it aligned after i put on the rims and tires next week if that doesnt fix it i guess ill try the calipers.... any thoughts?
There is a leak in both driver and passenger floor boards(the reason there was no carpet when i bought it) it seems to be coming from the windshield rubber.
other than that there is bad rust above the doors where the roof skin meets the door.... not sure what im going to do without major work.....
Cherub is offline   Reply With Quote
Old 01-11-2013, 07:49 PM   #2
Jonboy
Slots go on anything!
Re: Cherubs 4x4 suburban
Make sure the military tires you have are new or recapped, or are a matched set. There is a retread plant in my hometown that would do these, and they sold tehm either retreaded or before. I put a set of the non retreaded ones on my Blazer, and it would hardly stay on the road. They seem to be really sensitive to height difference.
On your breaks, I would suspect either the caliper or a brake hose. A collapsed hose will have the same effect as a stuck caliper. The alignment would cause a pull all the time, rather than just when braking.
Old 01-11-2013, 08:08 PM   #3
Cherub
Cherub's Avatar
double post
Old 01-11-2013, 08:10 PM   #4
Cherub
Cherub's Avatar
Thanks Jon. Ill look into the tires. As for the brake lines they are new.
Old 01-11-2013, 08:36 PM   #5
Edahall
My 82 Suburban is rusting in that same spot. I believe it's rusting from the inside out so like you said, it would require major work to fix it.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 01-11-2013, 08:40 PM   #6
Cherub
Cherub's Avatar
I really wanted barn doors so i may just live with it till i find a good donor body
Old 01-11-2013, 08:53 PM   #7
Edahall
The newer you go on these Suburbans, the less rust issues there are. In the mean time, you might treat it with some Por 15. It'll at least slow it down.
Old 01-12-2013, 07:29 AM   #8
tobiahr
tobiahr's Avatar
also check the rear brake drums...had a leaking cylinder on right rear on one of mine that made it pull hard when breaking
tobiahr is offline   Reply With Quote
Old 01-12-2013, 08:39 AM   #9
68Timber
I know the pieces fit
68Timber's Avatar
That's a good looking truck. Are you going to use those wheels with the new tires?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-12-2013, 03:32 PM   #10
zaccaglin
zaccaglin's Avatar
My burb leaks around the windshield seal to. Still racking my brain as to how to fix that shy of replacing the seal.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 01-12-2013, 03:48 PM   #11
Greenlee
Greenlee's Avatar
Check the cowl area under where the windshield wiper bracketry is. I have had a couple of trucks leak there. This causes the firewall to rust also.
Greenlee is offline   Reply With Quote
Old 01-12-2013, 06:24 PM   #12
Mr. 250r
Mr. 250r's Avatar
I had 36in military tires when i got my suburban as well and man we're they terrible on the highway for about the first minute but everything after that was fine lol just gotta run the flat spots out of them
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 01-13-2013, 01:08 PM   #13
Cherub
Cherub's Avatar
did some searching and a little water test and its the window seal..... looks like ill be getting another one from LMC and setting it.
Old 01-15-2013, 07:29 PM   #14
Cherub
Cherub's Avatar
Well i got them on and boy were you right after sitting at the work they vibrated for the first mile then they smoothed out.
Old 01-15-2013, 07:30 PM   #15
Cherub
Cherub's Avatar
Old 01-16-2013, 12:43 PM   #16
68Timber
68Timber's Avatar
Looks good.
John
74 Honda Z50 build
Old 01-16-2013, 06:25 PM   #17
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Nice score on the burb looks super clean from here. Looks great with the lift and tires good choice I would go with stuck caliper if its got new brake lines.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-16-2013, 08:27 PM   #18
tvblazer78
Low & Fast!
tvblazer78's Avatar
I want one!!! Nice job..
tvblazer78 is offline   Reply With Quote
Old 01-17-2013, 08:55 AM   #19
Cherub
Cherub's Avatar
thanks. Wierd thing about the pulling when braking. It has seemed to have gone away after i put on the new rims and tires....... I still want to check the calipers though.
Old 01-17-2013, 08:58 AM   #20
Cherub
Cherub's Avatar
what does everyone suggest for headligner when you dont have the oe board?
Old 01-17-2013, 10:55 PM   #21
Edahall
I would go to the junkyard and find a board. Don't worry if the headliner is sagging because you can pull it all off and glue new head headliner material (of the right color) to the board.
Old 01-18-2013, 12:26 AM   #22
tobiahr
tobiahr's Avatar
Originally Posted by edahall View Post
i would go to the junkyard and find a board. Don't worry if the headliner is sagging because you can pull it all off and glue new head headliner material (of the right color) to the board.
+1
Old 01-19-2013, 06:11 PM   #23
Psycho71
Psycho71's Avatar
Just curious...How does yours act on those tires?
My K20 burb hates them, it walks all over the road. I put a set of BFG radial MT's on it, and it drives like a dream compared tot he Bias 36's.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-21-2013, 02:34 PM   #24
Cherub
Cherub's Avatar
yea its not the best but for the price ill ride on these for awhile.
Old 01-21-2013, 02:59 PM   #25
Dave C
Dave C's Avatar
Dang man that's looks sharp. I sometimes wish I picked up a 4x4 instead of getting mine and bagging it.
What side of Houston are you from?
bagged 1989 burb regency conversion
Dave C is offline   Reply With Quote
