01-14-2013, 04:14 PM | #1 |
torson bar suspension
I have a 2006 chevy 1500 extended cab with torson bar suspension, I have checked other 2006 trucks they do not have the same front end or the same type of steering. I almost forgot it is two wheel drive. Anybody else have this setup. The rear springs were replaced they are not your regular 1500 springs they were almost $200 more than the regular 1500 springs, the truck sits higher in the front and rear than my buddies truck he also has a 1500. His has a stock suspension???????
01-14-2013, 05:22 PM | #2 |
Re: torson bar suspension
Do you have a K-member under the engine? If not, I'm thinking maybe your truck is a converted 4WD to 2WD with 2WD hubs and minus the 4WD running gear such as transfer case, etc.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
01-14-2013, 06:05 PM | #3 |
Fabricate till you "puke"
2 wd , heavy duty.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-09-2013, 12:44 PM | #4 |
My 04 GMC 2wd non HD was coil springs and shocks in the front with pack and pinion.
My 99 Silvy 4wd non HD is torsion bars and keys and has a idler arm, pitman arm setup Posted via Mobile Device |
02-16-2013, 11:29 PM | #5 |
I expect you have what my '04 has - "Sport suspension" I bought my truck new, it had the option listed on the window sticker and I never gave it much thought till I started trying to buy shocks and they were wrong. I ended up buying shocks for a 4x4 and they fit. In reality I think it is a tahoe suspension. It has a much firmer feel than the standard half ton. I like it a lot, I just wish it had the rack & pinion. Best I can tell this is a rare option.
-Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
